Projects Building an early offset sprint roadster. 8-8-24
Discussion in 'The Hokey Ass Message Board' started by Frames, Aug 9, 2024.
  1. neilswheels
    neilswheels
    from England
    hisis excellent, thanks for posting, definitely following these.
    Sharpone and porkshop like this.
  2. noboD
    noboD
    I am officially jealous. Thanks for posting this stuff.
  3. Frames
    Frames
    Had the headers chrome plated. Up until 1966 in S E Wisconsin modifieds no one ran a collector. 2024-11-29 17.01.13-1.jpg
  4. Frames
    Frames
    Making the seat. K I S. One piece. One short weld by the vise grip on each side. 2024-12-03 09.56.56-7.jpg
  5. Frames
    Frames
    2024-12-11 10.29.45-1.jpg 2024-12-11 10.29.45-2.jpg 2024-12-11 10.29.45-3.jpg 2024-12-11 10.29.45-4.jpg 2024-12-11 10.29.45-5.jpg 2024-12-11 10.29.45-6.jpg Building a buck to do the aluminum tail. The upper panel will be welded to the side panel at the middle of the hammer form. The panels at the joint will be annealed and shrunk. Then slapped over the buck with my ******* made with a wore out file and a piece of tubing. I didn't want a flat side so the hammer form was made in 3 pieces. Curved on the belt sander. Aluminum strip is my template for checking my sanding progress. 40 grit on the long sanding board.
  6. Very cool build keep the updates coming.
    Sharpone likes this.
  7. Frames
    Frames
    Louvered the rear panel. Working on the buck for a head rest. Fabricated the roll bar? Will have it chrome plated then weld on before powder coating the frame. 2024-12-16 14.15.18.jpg
  8. sr
    sr
    from Monterey
    You are an incredible builder. Everything you create is awesome!
    Sharpone and Outback like this.
  9. Frames
    Frames
  10. sr
    sr
    from Monterey
    I wish I had grown up working with you and learning your magic!
  11. sr
    sr
    from Monterey
    Do you have a photo of the simple seat you made up? finished.
    Sharpone, Outback and porkshop like this.
  12. Frames
    Frames
  13. sr
    sr
    from Monterey
    Nice of course and simple/clean
  14. noboD
    noboD
    They even look simicomfortable.
  15. Frames
    Frames
    I have a heavy duty 10 foot brake. Cut one side .090 thick aluminum. Leave the other side un cut for now so I can make what ever width seat I want. I take a guess at the center and put 3 breaks 1/2" apart to make the side turn. Flop the pattern then I cut the other side adjusting off my center mark to what ever width I want to make. Then cut. Then bend the second side. I stand on the bottom part and pull up the back rest. A little over pull to allow for spring back. Volia a seat. 2024-12-22 14.19.03-1.jpg 2024-12-22 14.19.03-2.jpg 2024-12-22 14.19.03-3.jpg
  16. sr
    sr
    from Monterey
    Genius!
    Sharpone, porkshop and Outback like this.
  17. Frames
    Frames
    sr, dana barlow, Sharpone and 3 others like this.
  18. sr
    sr
    from Monterey
    Do they need to be supported at the back of are they strong enough to be free?
  19. Frames
    Frames
    Normally the metal shapers would join the top panel to the side panel in the middle of the radius. I spent a lot of time making the top ends on the buck a hammer form. I was able to slap a full 90 degrees. No shaping needed on the side panel. Don't know if I saved any time. The soot on the panel is where I annealled it. 2025-01-04 21.49.29-1.jpg 2025-01-04 21.49.29-2.jpg 2025-01-04 21.49.29-3.jpg 2025-01-04 21.49.29-4.jpg 2025-01-04 21.49.29-6.jpg
  20. neilswheels
    neilswheels
    from England
    Loving this build and general info Dennis, we have never had cars like this in the UK. You obviously have a lot of experience building these. I have a couple of questions, hand clutch, is that instead of a foot clutch to change gear? If it is, how do you engage the clutch, change gear, and steer at the same time?
    What are the plans for it when its finished, can you still race them? Forgive me, it seems that your building older spec cars, is there a 'vintage' race seen for these? Just curious, really enjoying seeing the work.
    dana barlow and Sharpone like this.
  21. Frames
    Frames
    No room for a foot clutch. Left foot brake/Right foot accelerator. 1/4 mile track driver can start out in high gear no problem. [ 6.66 -1 rear end ratio ] Slip the clutch to get going for a 1/2 mile track. [ 5.56-1 rear end ratio ] No plans to race. Just really enjoy fabricating and living in the past. Present day W O O sprint cars have no clutch or trans. Push start only. Same with cars like mine back in the day. Picture 2024-05-20 19.52.08-1.jpg 2024-05-20 19.52.08-3.jpg 3 hand clutch race cars way in back.
    sr, alanp561, dana barlow and 2 others like this.
  22. Frames
    Frames
    I installed the side panel. The welding was done on the inside. Cut down the weld with a hard wheel. Then I fused the outside joint not having to add any filler rod. Hammer/ dolly and my trusty bulls eye pick . Hope to not use any Bondo. PS; Hope to get my friend a full time metal shaper to do the head rest.$$$ 2025-01-07 01.59.40-1.jpg 2025-01-07 01.59.40-2.jpg 2025-01-07 01.59.40-3.jpg
    sr, alanp561, dana barlow and 3 others like this.
  23. Frames
    Frames
    Darlington. Vintage race car show. 1.5 mile circle track. 3.35-1 rear end ratio. Ran with the pack over 100 M P H. Driver unfamilier with hand clutch. Quick instructions and away he went. If you want to start in 2nd gear. [ 3 speed trans ] Shift to high gear without using the clutch. img638.jpg
    neilswheels, sr, alanp561 and 7 others like this.
  24. Frames
    Frames
    Strong enough if you use 4 bolts at the bottom. I use 2 bolts and support the back against the rear fire wall.
    dana barlow, Sharpone and porkshop like this.
  25. Frames
    Frames
    The radius at the front and at the rear matched the hammer form. Because of all the shrinking at the center the radius ended up kind a square. I used a shrinking disc to get the squarness down. Took about 4 times. Looks pretty good now. I have 2025-01-10 20.39.45-3.jpg 2025-01-10 20.39.45-4.jpg 2025-01-10 20.39.45-5.jpg never seen anyone use a shrinking disc on aluminum. Because I didn't use any filler rod on the outside I may do a little more bulls eye picking and fileing.
  26. Sharpone
    Sharpone
    Absolutely beautiful!!!
    Dan
    porkshop likes this.
  27. Frames
    Frames
    A few divots remained by the weld seam so I used a little filler. All-Metal. I won't attempt to do the head rest. Life's too short. Full time metal shaper Damon will do that for me. 2025-01-26 14.49.43-3.jpg 2025-01-26 14.49.43-4.jpg 2025-01-26 14.49.43-7.jpg
  28. Frames
    Frames
    First time anyone said that to me. Honest.
    sr, Sharpone, porkshop and 1 other person like this.
  29. Frames
    Frames
    Nothing new to add to the supermodified [ Killer ] thread. Preparing offset roadster parts to go to the platers. Going to finish welding the side rub rails 2-10-25. The tail is finished except 2025-02-09 13.17.48.jpg for building the head rest. A job for Damon.
    neilswheels, porkshop and Sharpone like this.
  30. Frames
    Frames
    Google or facebook V.R.O.O.M. They race vintage race cars. *** Oval tracks. A flying start. Every one is in high gear when the green flag drops. No shifting required.
