Technical Building brackets - oscillating spindle sander??
Discussion in 'The Hokey Ass Message Board' started by Dan, Feb 3, 2017.
  1. Dan
    Dan
    Building all the brackets for our '34 frame. Large holes like those for axle brackets have been cut using the plasma. Does a decent job but would like to improve the finish a little bit. Has anyone ever used an oscillating spindle sander for metal work? Seems a smaller diameter drum might work to clean up the holes a bit??
  2. Rex_A_Lott
    Rex_A_Lott
    I usually use a die grinder with a carbide burr for that type stuff. You'll eventually need one for all the out of position stuff. Good Luck
  3. bct
    bct
    I have on parts where it matters. Works great the oscillating action keeps the paper sharp. Start at 40 or 60 grit .
  4. mgtstumpy
    mgtstumpy
    [​IMG][​IMG]
    What I use for fine finishing. Labour intensive and time consuming are the drawbacks
  5. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    I recently acquired one. The only real metal use I have put it to is fish mouthing exhaust tubing. But, I will be using it to contour brackets too. Beats a torch and a file!
  6. DdoubleD
    DdoubleD
    from Michigan
    Oscillating spindle sander do an awesome job of cleaning up parts especially parts cut on a radius. I like being able to use different size drums depending on what size radius you are finishing. Good luck post pics.
  7. Marty Strode
    Marty Strode
    What brand did you buy Bruce ? I used one in High School on wood (over 50 years ago), often thought one would be handy for final fit, and finish on brackets and tubes.
  8. upspirate
    upspirate
  9. Here is what I use, not as "chattery" as a die grinder. (about 2" diameter) Screws on a 5/8-11 angle grinder arbor. I get them from my welding supply store. IMG_1924.JPG
    David Gersic and bct like this.
  10. bct
    bct
    those are neat, im going to look for them. I've used the small ones but they disintegrate quick.
  11. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    Marty,
    Mine is a Harbor Freight. (green, which I'm told makes a difference)
    I bought it at a local car show/swap meet. Paid $50 for it and a 12" disc sander. Both were like brand new.
    I do a little woodworkng in my spare time :rolleyes: and figured I couldn't go wrong for the price.
    First time I used the disc sander for steel, I caught the sawdust in the dust chute on fire. That thing shot sparks out about 3'. I have thoroughly cleaned it now, and seems to work fine. If I ever use it for wood again, I will take it all apart before and after for cleaning. No problems like that with the spindle sander. I cleaned that one first:p!
