Technical Building headers - Buick Straight 8
Discussion in 'The Hokey Ass Message Board' started by Ebbsspeed, Mar 15, 2017.
  1. SSD
    SSD
    I was thinking about the same carb set up on my 230 flat head I have a couple of the Harley versions laying around super easy to tune
  2. Ebbsspeed
    Ebbsspeed
    @31Vicky with a hemi @gimpyshotrods I'm rethinking four carbs. Runner + port volume should be nearly the same as the individual cylinder volume, correct? The one thing I am concerned with is the lack of accelerator pumps on the Mikunis, whereas the Keihin has them. Maybe it's nothing to be concerned with, given they worked beautifully on the motorcycle they came off of. Any input is appreciated. Thanks for the replies so far.
  3. Fedcospeed
    Fedcospeed
    These are two pics of my sons work on a OT engine swap that will have a turbo.Same concept,1 1/4" SS Tubing and elbows Took him alot of time to cope each one to fit turbo(or carb) flange and get them all the same size and smooth. SS 16904625_902365519900212_1314905673201313636_o.jpg 16998164_902365596566871_9145246494523322092_n.jpg 16998164_902365596566871_9145246494523322092_n.jpg
    kidcampbell71 likes this.
  4. Ebbsspeed
    Ebbsspeed
    That's some nice plumbing!
  5. Which Mikuni are you using?
  6. Ebbsspeed
    Ebbsspeed
  7. Fedcospeed
    Fedcospeed
    Real simple carbs,we dealt with those on our microsprint. Your challenge is getting all that plumbing evened up.Please post some pictures of the progress!! Fedco
    31Vicky with a hemi likes this.
  8. Generally A 40 with an accelerator pump is good for 500 cc single cyl or 1000 cc twin with split pulses. That's going to be 240 cubic inches with 4 @ 40mm carbs on split pulses.
    Is that enough carb?
  9. Ebbsspeed
    Ebbsspeed
    I think it'll be close enough, since this engine isn't built for high RPM's. I may try the Mikuni's first. If they don't work out, I can always cut them off and try something else.
  10. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    Just want to add something here. In high school one of my buddies built a Harley Pan. He adapted a side draft Carter (YH?). The accelerator pump made a WHOLE new motor out of it. That thing would just plain fly when you twisted the throttle.
    I don't know if that helps or not but it sure made an impression on me. First bike I ever rode.
  11. Ebbsspeed, did the exhaust headers ever come to be?
    Ben
  12. Rusty O'Toole
    Rusty O'Toole
    Balance tube is important for smooth idle and low speed running. It costs practically nothing so why not have one. To my knowledge all factory multi carb setups have some kind of balance tube at least on cars.
