Hot Rods Building my first roadster in Kansas City
Discussion in 'The Hokey Ass Message Board' started by Tim, May 15, 2025.
  1. Tim
    Tim
    from KCMO
    I think standard trucks have two stars IMG_0150.jpeg this is my buddy Chris’s big red truck Clifford.
    Brians dash is phenomenal! He built that dash and had the entire thing chromed and then painted it leaving the stars and edge bead chromed and exposed. Dudes a genius
  2. atch
    atch
    I didn't know that about having two stars as mine has the hole where the right-hand star is and it's the only one I'd ever seen.
    osage orange likes this.
  3. Tim
    Tim
    from KCMO
    I think there are several different inserts for these dashes. I’m not into them enough to know which came on which. Or if maybe it’s a year to year thing. I’ve also seen some with ribs instead of stars.
    winduptoy likes this.
  4. winduptoy
    winduptoy
    yes, you could have 'two blue stars' .....
    instead of tube type....
    Tim likes this.
  5. Dunno if you saw it but on marketplace theres a t style cowl super cheap. It may actually be a Dodge but would still be a good start on a fabricated body. They have it listed as for a t
    winduptoy, osage orange and Tim like this.
  6. Tim
    Tim
    from KCMO
    In progress of making some legible drawings for reference. Some great hambers have reached out with cars for me to continue measuring and comparing to. I’m going to try to line some visits up in the coming month or so.
    making some templates off my buddies roadster here in then next 2 to 12 days. Anyhow here are two of the half dozen drawings I’m working on dialing in Untitled_Artwork.jpeg Untitled_Artwork.jpeg getting closer! Really looking forward to making the small scale body. Been doing some refreshing and test shapes in my non existent spare time but putting them all together for one project is sounding enticing.
  7. RodStRace
    RodStRace
  8. Tim
    Tim
    from KCMO
    @RodStRace ive been wondering if those existed! Thanks man good tip
    RodStRace, winduptoy and osage orange like this.
  9. Six Ball
    Six Ball
    from Nevada
    "Nearly all the beads are gone..." Is that a song by The Mamas and the Papas ?
    Toms Dogs, NoSurf, winduptoy and 3 others like this.
  10. atch
    atch
    Tim likes this.
  11. Tim
    Tim
    from KCMO
    Digging through photos of belly pans and stopped to scribble out the jist of how I’m thinking about bracing this thing and the sub rails. Nothing is to scale I just made it all sorta 3x1 box tube to make it easier to get out of my head quickly.
    Untitled_Artwork.jpeg I put the vertical in the wheel well to imulate a quarter brace you’d see on an A coupe, and I’m still thinking about a horizontal section from the b pillar to the curved back sections.
    Green marks are holes for a steering column support, door hinges, door latch and shoulder belts. Red is obviously a generalized body outline. Didn’t mark it but this also allows beef for mounting hanging pedals.
    I think the trunk will get an additional cross brace across the top of the side rails. The 32 frame rails kick up inside the flat subrails into the trunk space a little. I’ve seen some brackets reaching from the subrail to the frame rail, and I’ve seen the rear frame horns redirected to land under the tail of the body again to support it. But I think I like the idea of leaving the bobbed horns and running a full cross piece over the rails. I’m fine with 18” or so of body cantilevered off the back of the frame. It’s that way on basically ever stock one or T on A rails. I don’t see any reason to over think it.
    As far as how this all would attach to the skin of the body I haven’t really figured it out yet. I’m leaning towards plug welds, some in the flat areas and some the panels will have a bolted together flange that could be bolted to or welded to the structure. I think I’ll gather some ideas and then when I’ve got it in front of me do what makes the most since.
    edit: I’m aware of no floor cross pieces. It’s because at the moment I’m planning to have the floor at the bottom of the frame. Effectly making the frame rails a sandwiched bolted on part of the body. This also checks some boxes on belly pan visuals. I’m also not opposing some cross pieces for the body maybe around the A pillars. It could drop down into the floor or be in a section that’s under my knees.
    I noticed the Mumford track T located the trans cross member basically under the drivers knees with the seat pan dropped way down
    Joe Blow, Deutscher, Six Ball and 3 others like this.
  12. RodStRace
    RodStRace
  13. Tim
    Tim
    from KCMO
    That’s a good link, I spent a fair amount of time last night flipping threw a Snyder’s T catalog looking at the diagrams and illustrations like those.
    Six Ball and winduptoy like this.
  14. RodStRace
    RodStRace
    This may be poor advise, but it should be fairly cheap if you use wood. How many supports can double as bucks?
    The door openings for sure. A cowl loop probably.
  15. Tim
    Tim
    from KCMO
    Ya know you probably could with out much trouble but every roadster I’ve ever ridden in either had a full cage or I thought “**** I wish this was a little beefier” but there really isn’t really any room to play in one of these so my current thinking is basically replace the wood and stamped inner structures from the stock version and replace it with stronger pieces.
    I also love the behind the ****pit roll bars like those shown in a lot of my references. I didn’t show any of those ideas in the “sketch” but they will be thought out and planned before I start anything.
  16. RodStRace
    RodStRace
    True, but it's easier to carve out a curved door opening to the shape, get the sheetmetal to fit, then shape the metal replacement to match. Just tossing out ideas.
    I'm no woodworker so it's not simple for me, but I've read about building a simple car by placing the major components on the floor, then mocking up a basic frame out of 2x4s before cutting the metal.
    It's an additional step, but proof of concept and changes are not in the final frame.
    https://www.jalopyjournal.com/forum...gster-marty-strode-chris-kopp.1313966/page-13
    Six Ball and Tim like this.
  17. Rynothealbino
    Rynothealbino
    Boy you move fast. Sorry for the delay.
    It's 7" exactly in the center and 7.375" at the edges following the profile. There is a lot more shape at the edges compared to the center.
  18. Rynothealbino
    Rynothealbino
    Really poor picture but my stash of T decklids is coated in years of dust. You should probably come up for Back to the 50's and pull thorough patterns and measurements or better yet just throw the stuff in your trunk and drive away.
  19. Tim
    Tim
    from KCMO
    Tempting!
    for now I’m saving up some gas money and gonna go see Atch and grab a few bits and pieces.
    I snuck in an hour, maybe hour and a half this week to go start taking more deck measurements and start making templates. Did a fair amount of laying a straight edge on the car, opening the doors and trunk to look at the edges and inside. And just laying poster board over shapes to see what’s really going on.
    Feeling encouraged. I’ll share a few pics of that later on. But I think I’m on target for making the small body this summer still
  20. winduptoy
    winduptoy
    Went to our, once a month, east mountain cars and coffee
    This is an old build and has a 265 under the hood IMG_20250531_082431038_HDR.jpg IMG_20250531_082441733_HDR.jpg IMG_20250531_082451249_HDR.jpg IMG_20250531_082814226_HDR.jpg IMG_20250531_082844239_HDR.jpg
    Deutscher, jet996, Uncle Ronn and 6 others like this.
  21. winduptoy
    winduptoy
    It is a favorite of mine IMG_20250531_083247654_HDR.jpg IMG_20250531_083251982_HDR.jpg IMG_20250531_083324229_HDR.jpg IMG_20250531_083337897_HDR.jpg IMG_20250531_083348992_HDR.jpg IMG_20250531_083400788_HDR.jpg IMG_20250531_085724985_HDR.jpg
  22. atch
    atch
    That's a pretty dad gummed (© 3W Larry) sweet ride.
  23. Ebbsspeed
    Ebbsspeed
    I don't know about earlier ones, but a '31 Model A has a bead on each side of the trunk lid.
  24. Tim
    Tim
    from KCMO
    IMG_0233.jpeg Well I had to go back and take another look! Almost looks like it’s not there doesn’t it! Looks like the earlier A’s have a bead that’s much smaller, closer to the T strip used in the vertical seam on the back of a same year sedan.
    Now I’m curious if it isn’t a T strip on the 28/9 like it is in the 26/7. Also would explain why I thought I’d seen early cars with out it. Would be very easy to remove the T strip or have it go missing and the person who finds and builds the car never knew it was supposed to be there.
    anyhow there we go lol
  25. alchemy
    alchemy
    Yes, 28-9 A’s have a T strip on either side of the trunk like a T does. It’s thinner though.
    winduptoy, Six Ball and Tim like this.
  26. Tim
    Tim
    from KCMO
    Seems the T stripes are pretty beefy I’m curious how a guy would go about making some.
    IMG_0238.jpeg This is kinda how I’m picturing all the folds , loosely obviously.
    winduptoy and Six Ball like this.
  27. NoSurf
    NoSurf
    I think the bottom of the T folds back up in between maybe?
  28. Tim
    Tim
    from KCMO
    Could be. Outside of maybe a pull max I’m thinking maybe you could bend the four 90 deg bends and then maybe make some sort of inside form for the inside and a C shaped/
    Cupped roller to push on the outside.
    sorta like a bead roller except the lower die is inside the piece not under it. You’d have to bend the curb after the fact but shrinking and stretching the vertical parts.
    or maybe roll the bead first and then use one of Baleigh’s magnetic brakes?
    wondering nine of the old ford ***embly line videos has some
    Clues how they did it
  29. justabeater37
    justabeater37
  30. Tim
    Tim
    from KCMO
    @justabeater37 any idea how you would fold some up? Looking at that photo it seems you could fold it all flat and then hammer the crown into the visible “bead” area
