Projects Building My First Roadster in San Francisco
Discussion in 'Traditional Hot Rods' started by J.Ukrop, Sep 7, 2020.
Tags:
  1. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Sidebar 290: The Wall
    Even though life has been busy, I've been working to get the car ready for its first fire up. Last night, I sorted out the radiator hoses and filled the radiator with water.
    It's a NOS Walker, and I'm still grateful that I spotted it at the swap meet in Texas last spring. I was happy to have no leaks from the radiator or any of the hoses.
    Today, I went down to the garage to fill the engine with oil and wire up the ignition. I was excited to finally be filling this thing with fluids again. I checked the dipstick: all good. Before I went upstairs, I figured I'd squirt some more oil down the cylinders and see if I could turn it over with the starter. I remember doing that the night before 1.0's first fire up. When the 'banger turned over, I knew it was going to run.
    I felt confident as I hit the ignition on 2.0. Errt. Nothing. Errt. Nothing—just clicks. I tried removing the starter to see if anything seemed wrong. I switched batteries, cables and ground points, none of which helped. I then unbolted the wishbone mount and unbolted the rear portion of the oil pan to expose the flywheel. Using the flywheel tool—with the spark plugs out—it wouldn't budge. Seized—again.
    How? The engine rotated perfectly smoothly in the bed of the truck and on the stand. Now that it's in the ch***is, it's locked solid. What's the common denominator here? The "rebuilt" transmission. I pulled the lid.
    Regardless of what I do, this input shaft will not spin. I Facetimed David and we tried every combination. Clutch in, clutch out, didn't matter—it's stuck.
    So, although everything is all put together, it'll have to come back apart again. That'll be later this summer. David and I are rebuilding transmissions at his shop then, and I'm ready to finally get this thing to work.
    Not how I wanted to spend the first half of my day off, but that's just the way it goes. I'm going to clean up the garage tonight and hopefully start fresh sometime soon.
    JalopyJimbo, rod1, warbird1 and 6 others like this.
  2. RodStRace
    RodStRace
    Eh, just pull start it! :D
    Six Ball likes this.
  3. 41 GMC K-18
    41 GMC K-18
    "Perfection, cannot, and WILL NOT, be rushed"
    Dam @J.Ukrop !
    It's gotta be something so uniquely simple, yet complex as the culprit is hiding in plain site!
    I seriously doubt that squirting the oil in the cylinders,
    caused a type of hydraulic lock such as is found in the bottom cylinders, of radial engines, when they sat for a while!
    I hope the remedy will be found so that you can get to enjoy 2.0 very soon!
    Good luck from Dennis.
  4. 51504bat
    51504bat
    This info is from a post on the early V8 Club Forum regarding Powermaster alternators.
    https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=16437&srow=11&erow=20
    The pulley you need is most likely available from Fifth Avenue, phone 785- 632-3450. It is part number 14415FP. It provides both the mount for your fan and the proper 2.5" diameter pulley for your alternator to charge properly at idle. The stock Ford pulley has a diameter that is too large for the alternator to charge properly. Alternators have to spin faster than generators to function as intended.
  5. j ripper
    j ripper
    from napa ca.
    What’s the clearance like with that clutch you put in there?
  6. Outback
    Outback
    from NE Vic
    Dang, but you are still moving forward. All these hold ups are frustrating, but work together to make victory - cruising up the road - more sweet! If it were easy everyone would do it ;)
    Keep pushing forward
    Six Ball and 41 GMC K-18 like this.
  7. Six Ball
    Six Ball
    from Nevada
    Like j ripper I wonder about the clutch plate. Could it be flipped and binding on the flywheel bolts or tweaking so it won't release. It seems like it should turn in neutral unless the pilot shaft is pushed back and taking up all the ****** end play. Are there different length noses on the Ford pilot shafts? Different spline lengths? I know there are different clutch hubs.
    Irish Mike, Outback and 41 GMC K-18 like this.
  8. RodStRace
    RodStRace
    If engaging/disengaging the clutch made no difference
    1. box is locked.
    2. input shaft is bottomed out or stuck in bushing/crank.
    3. clutch disc is too far back on shaft or too far forward on flywheel, and won't release. Check clutch plate gap before dis***embling, too.
    Irish Mike, Six Ball and 41 GMC K-18 like this.
  9. circlek454
    circlek454
  10. circlek454
    circlek454
    I agree with everything RODSTRACE has to say.
    Some additional thoughts:
    The trans case does not look to have fluids in it, I could be wrong here, on this trans, but even at idle, with the input shaft moving , the cluster gear roller bearing movement could lock up the trans, with disastrous results.
    A simple test to prove out pilot shaft length interference would be to remove any rear trans mount bolts, then loosen trans to bellhousing bolts and move trans case back a little with a large screwdriver or prybar
    Have rear wheels off the ground for safety sake
    Now, disconnect coil wire and attempt to crank engine
    Good luck kid , from Kentucky
    41 GMC K-18 and Six Ball like this.
  11. RodStRace
    RodStRace
    Oh, throwout bearing snout could also be locking on the pressure plate, if the parts are mix and match.
    Thanks, circlek454! I'd go with a socket on the crank, no need to force things unless you want BIG DEEP witness marks! :cool:
    Outback, 41 GMC K-18 and Six Ball like this.
  12. j ripper
    j ripper
    from napa ca.
    Ok. I rifled back through a bit of this thread. When you first tried rolling this over and it was stuck attached to transmission, was it set up with an 11” clutch? I’m not certain what case you have, but do some of the early ones say a 48 number case not except this big of a clutch? I’m not certain of this as I would never consider a clutch of this size in a car like this. I hope this is the problem as it would be a simple fix.
    seadog, 41 GMC K-18 and Six Ball like this.
  13. Six Ball
    Six Ball
    from Nevada
    I bought a '38 sedan that had 1st & reverse. Trying to put it in 2nd or 3rd locked it up. After much head scratching I found that the 2nd/3rd synchro slider was turned around by the guy I got the car from. The shift forks put the synchro in the wrong spot. Make sure it is really going into neutral. And what RodsRace says.
    Is the pilot bearing fully seated?
    RodStRace, Outback and 41 GMC K-18 like this.
  14. Tim
    Tim
    from KCMO
    Bud it’s gonna be something super simple. Rebuilding one of those transmissions is easier than changer the oil in a lawn mower. I’d see if you can bolt some elbows to the bell housing for a jack stand to land under and leave the engine in place while you pull the trans.
    You’re close man!
  15. Jeff34
    Jeff34
    Hey Joey, bad luck on first startup. Why not remove the trans/diff and start the engine on it's own? Drive down to the lowest common denominator.
  16. Hitchhiker
    Hitchhiker
    This was my thoughts as well. To big a clutch for the case. I saw someone get their engine running with this issue and blow the bellhousing out of the transmission case. Big boom.
    ottoman, warbird1, Tim and 2 others like this.
  17. j ripper
    j ripper
    from napa ca.
    I’m willing to bet this is the problem. A simple pick of the engine away from trans would answer so many questions.
  18. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Hi everyone, I'll dive into more in-depth replies soon. Yes, the engine originally had an 11-inch clutch on it. I bet you're all correct. Maybe a smaller clutch and pressure plate is in order. If so, what size?
  19. Hitchhiker
    Hitchhiker
    Do you know what case your trans has? If it were me I'd step down to a 10 inch clutch.
    If I remember right it's a #48
    41 GMC K-18, J.Ukrop and Six Ball like this.
  20. Six Ball
    Six Ball
    from Nevada
    The engine block part of the bell housings are all the same. I thought the ****** side was too. Maybe not? I ran 11" clutches on several flatheads and a LOT of transmissions. :rolleyes: I don't remember searching out bigger cases. Just luck maybe?
    41 GMC K-18 and J.Ukrop like this.
  21. I'll also pile on and say that the pressure plate looks a little big to fit in where it's supposed to live. When you get the transmission separated look for any shiny witness marks where it tried to turn when the starter was energized and ran into a bind. Don't forget your gear lube for the transmission too, all of the internals will be spinning even in neutral, your gear teeth and needle bearings will thank you
  22. Hitchhiker
    Hitchhiker
    I'm only regurgitating stuff I've read here, so very well could be wrong. But I have been recently researching clutches and flathead v8 combos for several projects I have coming together.
    If Joey, has an early case they only fit the 9 and 10 inch clutch, from what I've read.
  23. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Update: it is an early trans case. Screenshot 2023-05-30 at 11.16.15 AM.png
    I have a second trans back at the house. I'll inspect it when I get home this afternoon.
  24. Hitchhiker
    Hitchhiker
    Another thing to note, is a lot of guys(Bruce Lancaster is one) that say a 10 inch clutch performs better because of less rotating m*** and that the 11 performs poorly in comparison on a relatively stock engine.(bruce said it was for dump trucks to be exact.) And that a light car like a roadster doesn't need an 11 inch clutch anyways. Again. Just regurgitating info I've read..... From guys I trust...
  25. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Got it. That would require a new flywheel, clutch and pressure plate, right? I suppose this one could be re-drilled, but that's probably more trouble than it's worth.
  26. krylon32
    krylon32
    from Nebraska
    All you need is a 9 inch clutch and PP with medium springs. Redrill the flywheel and you should be good to go? I'm sure you have some good early parts houses in your area but if not I send all my customers to Fort Wayne Clutch, ask for LOU.
    Six Ball, 41 GMC K-18 and pprather like this.
  27. Tim
    Tim
    from KCMO
    Or just put all the guts you have in the later case and go on about your day….
  28. Nobey
    Nobey
    I'll bet the pressure plate is making contact with the transmission housing, this happens with bigger
    pressure plates and top load transmission. Loosen the transmission bolts and let it slide rearward,
    then try and rotate the engine with the front pully bolt. If the transmission is in neutral you can
    jack up the rear end and spin the wheels. Even if the in the input shaft is looked up on the engine
    the rear portion of the gear box will still rotate. If it rotates that means the problem is in the bell
    housing......
    Six Ball, Tim and 41 GMC K-18 like this.
  29. j ripper
    j ripper
    from napa ca.
    Not sure how much separation/relief you could achieve with a 32. The engine needs to be separated or the whole unit needs to come out from the front of ch***is, but it could be just enough to at least get it to spin by hand and confirm the issue.
    41 GMC K-18, Six Ball and Nobey like this.
  30. Nobey
    Nobey
    I almost forgot to mention the flywheel. The four bolts come in deferent lengths, if you use
    ones that are too long, they will go in against the pan and lock up your engine. You can look
    from the bottom of the engine and see this situation without removing anything. Look between
    the pan and the crank flange.....
