Projects Building one from two, 41 Ford
Discussion in 'The Hokey Ass Message Board' started by ricky_tbird, Jul 6, 2019.
  1. ricky_tbird
    ricky_tbird
    Picked this 41 up in March. Was a few states away and I got lazy and didn't look at it. Was on an S10 frame and supposedly had minimal rust. When it got home I realized it's junk. Rockers gone, S10 firewall glued in with galvanized sheet metal, frame shortened with a hatchet and soldering iron. Lesson learned, luckily it was cheap. Pulled it off the frame which was promptly given away. IMG_20190310_172752987_HDR.jpeg IMG_20190618_115935490_HDR.jpeg
    Tim, Stogy, chryslerfan55 and 2 others like this.
  2. ricky_tbird
    ricky_tbird
    Found this 48 a few weeks later. Was dipped and primed. Rocker are perfect, minimal rust in the floor and original unmolested frame. And front doors in a sedan are identical to business coupes.
    Sent from my XT1710-02 using The H.A.M.B. mobile app
  3. ricky_tbird
    ricky_tbird
    My own private junk yard.
    Tim, adam401, Stogy and 5 others like this.
  4. ricky_tbird
    ricky_tbird
    Tim, adam401, Stogy and 2 others like this.
  5. ricky_tbird
    ricky_tbird
    Looking better. MrMusico's coupe is an inspiration. Chop will be similar as I won't lay the back window down too much. Will keep the drip rail and exterior trim also.
    (I think I mangled this thread with replies also. Apologies. New to the app) IMG_20190706_115726152.jpeg
    adam401, Stogy, Peanut 1959 and 7 others like this.
  6. topher5150
    topher5150
  7. Jalopy Joker
    Jalopy Joker
    Boy, nice easy project
  8. patterg2003
    patterg2003
    Peanut 1959 likes this.
  9. King ford
    King ford
    from 08302
    I myself like the look of the roof angle in post 5 ....I understand you have to tie it all together but what appears to be your plan looks good!
  10. ricky_tbird
    ricky_tbird
    This was the cut I was most concerned about. Wanted the roof top to blend in with the back window section. Don't have the tools or the skills yet to build patch panels to piece the two together seamlessly. Well it worked out perfectly. The profile looks spot on.
    Tim, VANDENPLAS, adam401 and 6 others like this.
  11. ricky_tbird
    ricky_tbird
    Front and rear roof sections welded together and roof attached at A, B and C. Should get the catwalk and quarter windows roughed in this next week. IMG_20190714_202326617.jpeg
  12. ricky_tbird
    ricky_tbird
  13. ricky_tbird
    ricky_tbird
    Quarter windows and catwalk roughed in, started door frames and fender skirts. The rear of the skirts look good but not happy with the front, too boxy.
    IMG_20190728_195135107_HDR.jpeg IMG_20190728_140537072.jpeg IMG_20190727_182432567_HDR.jpeg
  14. ricky_tbird
    ricky_tbird
    I received a bunch of small parts with the sedan. Can any 40s Ford experts out there help me identify them? Thanks IMG_20190817_162207126.jpeg
    tr_rodder, Tim, Thor1 and 1 other person like this.
  15. topher5150
    topher5150
    Looks like fender tops far left, fender bracing in the middle, maybe a rad splash shield on top
    Sent from my moto z4 using The H.A.M.B. mobile app
  16. Well, I can identify some of 'em for sure and guess on the rest...
    Left to right: L/R '47-48 inside fender halves (these have two-piece fenders), below them is a front fender brace (between the fender and inner fender), next to that is the driver's side rear fender brace/splash shield, above is probably part of the radiator splash shield (the lower part is my guess), the mirror pair of parts are the inner filler panels on either side of the radiator, top piece I'm not sure, but may be the p***enger rear fender brace, with the remaining parts being the rear splash shield between the body and rear bumper (both ends and the middle).
  17. ricky_tbird
    ricky_tbird
  18. Jim Bouchard
    Jim Bouchard
    The top piece is the air deflector that goes behind the grill but in front of the radiator. It looks upside down in the picture. It also attaches to the front splash shield behind the bumper
  19. ricky_tbird
    ricky_tbird
    Work continues...
    IMG_20201130_163442259.jpg IMG_20201130_163731542.jpg IMG_20201130_163937619.jpg IMG_20201130_164044302.jpg
    Making drip rails from the sedan I cut up. Fenders and doors are done after fixing a million cracks and dents. Bottom 2 inches of deck lid was rotten and had rust in the inner structure. Pulled the deck lid skin off the frame and fixed the rust and shot it with epoxy before re***embling. Like most 41's the tail pan is rotten also so making up a new one. I know there are new stampings out there but they are pricey and I like a challenge. Worked on the front and rear suspension also. Found some short rear leaf springs off an early 90s Isuzu pickup and fabricated spring hangers similar to TCIs setup where the front mount is inboard of the frame to lower the rear. Sectioned the front crossmember to lower the front and fabricated some front and rear sway bar mounts. If this pandemic thing keeps up and with a little luck maybe will have it running and driving by the summer.
  20. T&A Flathead
    T&A Flathead
    Nice job. I’m doing something similar for a convertible. I used a donor Tudor but it wasn’t as nice as your 4-door.
  21. ricky_tbird
    ricky_tbird
    Work continues. To cold to do any body work so focusing on the fiddly bits.
    Drip rails are in. I cut them off the sedan body leaving about half inch flange. Bent them up with a hacked together jig and mapp torch. I ground out the seam with small cutting wheel and glued them in with 3m panel adhesive. Worked really well, seemed to add rigidity to my top, and know that water will not get in the seam.
    Garnish moldings and vent windows all roughed in and functional. Doors gapped and running boards fitted. Of course every bolt had rusted and been previously broken to get the running boards off so small patches were cut out from the rockers and new caged nuts welded in. Also, after monkeying around with stock trunk lid hinge springs decided to make my own out of some gas struts from a 280z and some s**** metal. With the strut pivot up high was able to take advantage of leverage to keep the lid open when the strut is extended and keeps the lid closed when compressed.
    IMG_20210124_102222745.jpg IMG_20210124_102302674.jpg IMG_20210124_102333750.jpg IMG_20210124_102432826.jpg IMG_20210124_102548785.jpg
    tr_rodder, Tim, goldmountain and 3 others like this.
  22. ricky_tbird
    ricky_tbird
    Fast forward a bit. Slippery as ****er. Will post more pix when it gets ***embled
    Tim, warhorseracing, AndersF and 3 others like this.
  23. AndersF
    AndersF
    Looks great. Really like the way you did the back of the roof.
    Tim and ricky_tbird like this.
  24. ricky_tbird
    ricky_tbird
    Starting the ***embly process. Seemed like it took three months to wet sand and polish this spring. Over the winter I rebuilt a 350 and finished up some of the mechanical ***embly.
  25. vtx1800
    vtx1800
    nicely done, I have always liked the 41 front styling.
  26. Tim
    Tim
    from KCMO
    Holy ****.
    Man first I thought wow big balls on this dude to just jump in.
    Then I thought oh **** that’s clever!
    Scrolling down I couldn’t help but think how easy you made that look. Your nailing it dude!
    Thor1 likes this.
  27. choptop40
    choptop40
    looks great...nice and well thought out,,,hoodlum award
  28. ricky_tbird
    ricky_tbird
    It's been a minute but there always seem to be a million little things to do. Almost done. Waiting on my wide whites
    IMG_20230807_131954844.jpg IMG_20230807_134058311_HDR.jpg IMG_20230807_134153849_HDR.jpg IMG_20230807_134305172_HDR.jpg IMG_20230807_134409430.jpg IMG_20230807_134530855_HDR.jpg IMG_20230807_134547154_HDR.jpg IMG_20230807_134647102_HDR.jpg IMG_20230807_141606845_HDR.jpg
    Thor1, X38, Ferdyeight and 2 others like this.
