Built 401 AMC and 727
Discussion in 'Parts For Sale' started by cosbysweater, Jan 14, 2020.
  1. cosbysweater
    cosbysweater
    City: central coast
    State: California
    Price: 7000
    This combo was just removed from my 1974 AMC Gremlin. The previous owner had the engine and transmission professionally built with the finest parts available and has only a few hundred miles on it. This engine and trans combo worked great when it was in the Gremlin and will drop right into various AMC vehicles from this era. I am basically including EVERYTHING to make this engine and trans combo bolt right into your Gremlin. Engine mounts are not included but are readily available. Minor chipping on the flex plate but it does not affect anything. Specs below.
    360 block
    Forged 401 crank and rods
    Custom JE pistons
    Edelbrock Performer 401 aluminum heads
    ARP head bolts
    Dual beehive springs and hardened push rods
    Comp Cams valvetrain
    Edelbrock Performer intake
    Oil pump mid plate and standard AMC oiling mods done
    Comp Cams custom grind camshaft
    Flamethrower distributor
    Stock accessory drive and brackets (alt, power steering pump, water pump)
    Built 727 transmission w/torque converter and speedo cable for stock AMC speedometer
    MSD starter
    Lokar kickdown cable
    Trans temp sensor plumbed to the trans
    Custom drop in aluminum radiator with 2 speed e-fan and shroud
    Coolant hoses
    Drive shaft custom made to bolt to a Ford Ranger 8.8 rear end
    2.5" dual exhaust that bolts onto a Gremlin with supplied hangers
    Also comes with mechanical fan and custom shroud
    Custom aluminum radiator
    Mechanical fan and custom made fan shroud
    I have videos of this engine running, the valve train operating with the valve covers removed, and me draining the oil and transmission fluid when I removed the engine from the car. I am willing to ship this in a crate for the right price.
    I have it listed on craigslist right now and I am working on getting some pictures uploaded. if you would like to contact me , send me a pm for a phone number. here is the link with current pics.
    https://monterey.craigslist.org/pts/d/seaside-amc-401-engine-and-727/7047002493.html
