Projects built lots of cars, but never a 32 roadster...
Discussion in 'The Hokey Ass Message Board' started by SDS, Oct 14, 2021.
  1. DDDenny
  2. X38
    X38
    One of those rubber plugs used in brake drum adjuster slots? May come in a variety of sizes?
  3. DDDenny
  4. vtwhead
    vtwhead
    Have you tried the plug from a rear backing plate?
  5. 19Eddy30
    19Eddy30
    from VA
    Hardware store
    You have a 3d printer
  6. I’m ***uming that the aforementioned son ( child that is) happens to be your project supervisor? Right?
  7. SDS
    SDS
    Not at all, he's 12 and it's hard to keep his attention on this project (unless the task involves polishing, then he's on it)
  8. X38
    X38
    It's interesting what you respond to.:rolleyes:
    05snopro440, Tman and XXL__ like this.
  9. SDS
    SDS
    For sure, Tuff Stuff sent me a kit with all new internal parts... going to try and rebuild it. That's a new one for me, hope it works (no leaks).
  10. SDS
    SDS
    PXL_20230701_180129770.jpg How in the world do these make love?
    Doesn't seem to be a clear place for the rubber deck lid seal to live...
  11. SDS
    SDS
    Like this?
  12. pprather
    pprather
    That makes sense to me. What happens to the water when it get to the bottom of that channel?
    How does the rubber stick to the ridge? Two side tape or sticky black stuff?
  13. 19Eddy30
    19Eddy30
    from VA
    Im sure there is no seal originally,
    ( @ least I have not seen ""Original"")
    Just Rubber bumpers , @'top for rumble
    Bottom for deck / Trunk,
    Water runes down channel ( Original) in trunk /roll pan then out drain holes,,
    But you can make catch can
    ( end of drip rails One each side) then route hose to drain holes
    As you can see a """32 "" not like other cars
  14. X38
    X38
    No seal originally. At the bottom channel, make a drain hole with tube attached to direct liquid out under the body.
  15. NJ Don
    NJ Don
    Yup, no seal.
  16. SDS
    SDS
    Thanks y'all - I had Brookville installed the little drains at the bottom of the channels.
    This is a great thread on the topic:
    https://www.jalopyjournal.com/forum/threads/32-trunk-lid-seal.965178/
    From that, I gathered that there is no seal originally, but thought this might be a good add-on.
    Steele Rubber products are typically pretty nice. This, however is a boggler.
    It's too short to put in the channel (would not contact the trunk lid)... And there's no place to put it on the deck lid.
  17. pprather
    pprather
    I would call it a dust seal or weather seal. Rain is well channeled away by the trough and weep holes.
  18. SDS
    SDS
    FYI, here's how far you get with one box of Kilmat sheets from Amazon:
    PXL_20230704_175956622.jpg PXL_20230704_180015336.jpg PXL_20230704_175940849.jpg PXL_20230704_180022789.jpg PXL_20230704_175946300.jpg PXL_20230704_180008523.jpg
    I was very efficient with my usage and this is all that's left, small s****s
    brEad likes this.
  19. Dick Stevens
    Dick Stevens
    I won't buy KILMAT because it is made in Russia!
  20. vtwhead
    vtwhead
    Wow, never knew that.
  21. SDS
    SDS
    China are bad guys too...and you're on a computer or phone made there, I'm just sayin'
    brEad and Anderson like this.
  22. SDS
    SDS
    Need your experienced opinion:
    Put radiator in grille shell on a bench, then install on car
    OR
    Put radiator on car, then install grille shell?
    Both have their own pros & cons
  23. Anderson
    Anderson
    Radiator on car first. Don’t know how or why you would do it differently.
    X38 and 05snopro440 like this.
  24. vtwhead
    vtwhead
  25. SDS
    SDS
    Thanks, guys!
    When I was mocking everything up, I always ***embled the shell to the radiator on the bench, then put it on the car. Was easy to get the shell on the rad, but was really hard to get the bolts into the frame
    Motorwrxs, brEad and Anderson like this.
  26. 19Eddy30
    19Eddy30
    from VA
    ^^^^^^More easy to jack up front end ,let axle extend down ward ( leaves of springs)
    1/4 5 inch long Extension with wobble socket , ( nut underneath )
    Easier to install Rad & then Shell
  27. SDS
    SDS
    Figured you something that I didn't know...
    The slot in the hood hold down's lower bracket is not symmetrical from left to right, more distance to outside...
  28. SDS
    SDS
    Getting closer...
    PXL_20230723_160228658.jpg PXL_20230723_160352503.jpg PXL_20230723_160334258.jpg
    brEad, Bcap55 and Anderson like this.
  29. SDS
    SDS
    I need some advice on getting everything aligned. The body bolts are all in, but not tightened (washer under bolt heads is loose).
    The bolts on the brands brackets at the end of the cowl are also in, but loose.
    The p***enger side door gap is actually perfect, the driver side is a little off. The hood fits miserably.
    Where do I start and what should I attack- tighten up and/or shim first? Is there a preferred order on how to tighten the body bolts down, how about the other components such as the radiator?
    Thanks in advance ~
  30. Happydaze
    Happydaze
    The way I've done it: get the body bolted down and shim etc as necessary for the doors. Ignore the hood. Once happy with body set grill to correct height and measured distance for hood tops and sides. Fit hood and tweek to fit ( rad up / down, left right, tilt forward / back. The rearward corner bumpers on the hood sides do a great job of determining the gap to the cowl. I'm not aware of any particular ' tricks'. Some ***emble the hood completely and offer up. I've found just doing the tops first followed by the sides work for me. Helps if the side rods will go in fairly easily. Even better with one of those hood side caddy things pre installed on the cowl to rad rods. All not as daunting as it sounds, especially as I tend to overthink and overcomplicate things!!
    Chris
    Chris
    19Eddy30, Anderson and SDS like this.
