Projects built lots of cars, but never a 32 roadster...
Discussion in 'The Hokey Ass Message Board' started by SDS, Oct 14, 2021.
  1. NJ Don
    NJ Don
    I'm sure if you look under most hot rod dash's you'll see bird nests!
    I like your fold down relay mount!
  2. SDS
    SDS
    100A maxi-fuse on both the panel feed from the battery (starter hot lug) and the alternator output-to-starter hot lug
    brEad likes this.
  3. SDS
    SDS
    Pretty amazing how after putting Kilmat inside the quarter panels, shutting the door sounds solid - before, it sounded like beatumg on an empty steel drum
  4. SDS
    SDS
    Hallelujah! Finally got the wiring finished...
    PXL_20231025_221420818.jpg PXL_20231025_202034330.jpg PXL_20231025_202024039.jpg PXL_20231025_202012719.jpg
    Now, on to the interior
    Stogy, brEad, oliver westlund and 6 others like this.
  5. NJ Don
    NJ Don
    Scott,
    When I got my car it had a Glide seat with adjustable seat back, flip-up bottom and seat sliders.
    At 5'7" I was a bit cramped. I ended up removing the sliders and seat back adjuster and still had my upholster remove some foam from both the seat back and bottom. He said "you can never sit too low in a roadster". I finally got it quite comfortable. I did raise the front of the seat about 1 1/2" and added about 1" foam to the lumbar area to be more comfortable on long drives. You're pretty tall so try to get as comfortable as possible now rather than later.
    brEad likes this.
  6. SDS
    SDS
    Thanks...I took this advice from the beginning and chopped-up an S-10 seat to customize it for my size. The "*** surface" is about 9" from the floor with no compression. I also slightly tucked it under the lip of the panel forward of the trunk lid to get the "back surface" as far rearward as possible. I just have to upholster everything now.
    Stogy and brEad like this.
  7. ekimneirbo
    ekimneirbo
    from Brooks Ky
    First time I came across your build thread. I'd like to say you not only did an excellent job building your car, but an excellent job do***enting how and why you did it. Thank You.............;)
    05snopro440, Algoma56, Stogy and 3 others like this.
  8. SDS
    SDS
    Thanks... had to do something to keep the wife outa my head. :confused:
    Algoma56, Stogy and ekimneirbo like this.
  9. 19Eddy30
    19Eddy30
    from VA
    Nice work !!
    The most discouraging thing not to be negative is when you check all your circuits ,relays, gauges ,sensors etc. & tested.
    Its all tidy, (heat shrink ,zipped tied , soldered, Then you have a problem :mad:
    after start up ,driving & have to undo your work especially under the dash.
    Algoma56 likes this.
  10. Duke
    Duke
    @SDS did you figure out why your door handles were dropped down? Mine have the same problem. How did you get the hinge pins to go in past the knurled section at the top? Thank you
    Stogy likes this.
  11. SDS
    SDS
    Yeah, yeah, yeah ...
    I've spent three or four hours over the past 2 days trying to debug the electrical system- went ahead and removed all of the zip ties on the troubled circuits, so now it's a super mess under the dashboard
    Algoma56 and Stogy like this.
  12. SDS
    SDS
    My door handles drooped because they are not properly clocked... Not sure if it's the mechanism in the door or the handle itself, but as others have mentioned, the fix is to remove the shaft and twist it in a vise.
    As far as the hinge pins, I haven't gotten that far yet, but I'm planning to put a block of hardwood on both sides of the hinge and squeeze it with a 4 or 5-in c-clamp.
    Stogy likes this.
  13. Duke
    Duke
    Thank you, did you figure out the dovetails and the door rubbers? Looks like the rubbers need to be sanded down. Is there enough material in the door to tap the holes for the male dovetails?
    Stogy likes this.
  14. SDS
    SDS
    Yes, I did sand down the rubber bumpers for the doors with a flat disc on a 4 and 1/2-in grinder... I had to shave close to a quarter of an inch off of a few of them.
    My body is a Brookville body and had quarter inch thick steel underneath where the dovetails bolt on- I drilled and tapped them after I got them positioned properly.
    Stogy likes this.
  15. Duke
    Duke
    Thank you, I was hoping they put some thicker metal in there.
    Stogy likes this.
  16. SDS
    SDS
    Fired it up last night, air got trapped in the Zipper riser and it over-heated. bled the air out and it was fine. Cam seemed to break in just fine. 180 thermostat, I think I may need to get the fan closer to the radiator with a spacer and may need a fan shroud.
    Stogy likes this.
  17. NJ Don
    NJ Don
    If you're running a hood why not go electric?
  18. SDS
    SDS
    No way, brotha !
    Mechanical's why I got the Zip riser
    Stogy and teach'm like this.
  19. hotrodA
    hotrodA
    Great wiring! Maybe I missed it, what is the ribbon wire to?
  20. 19Eddy30
    19Eddy30
    from VA
    Some Zipps have a bleed some do not , if not drill tap top of riser , air still trapped ,& found agood way is to use one of those funnels that attach to neck of Radator start up let run for 5-20 mints , it will burp all air out , or a vacuum fill Im always changing power plants
    I run the fan 1/4 to 1/2 from core.
    Stogy and SDS like this.
  21. SDS
    SDS
    Steering column
    Stogy and hotrodA like this.
  22. SDS
    SDS
    I got the Lokar low profile, emergency brake and all the cabling installed this weekend. Took the car down off the wheel dollies and proceeded to put it in gear- not enough transmission fluid in it, duh. Have a few more minor things to do, including putting the hood on for good, then I'll start on the interior. PXL_20231112_232156605.jpg PXL_20231112_231340284.jpg PXL_20231112_231346654.jpg
    pbr40, IronFord, brEad and 7 others like this.
  23. hotrodA
    hotrodA
    That’s really looking good!! Wish Mine was that far along. Thanks for the inspiration.
    Stogy likes this.
  24. 19Eddy30
    19Eddy30
    from VA
    Nice looking!!
    I do not think you will forget your Tag #;)
    Stogy, vtwhead and Tim_with_a_T like this.
  25. SDS
    SDS
    Got the hood on and reasonably lined up.
    Going to thr alignment shop tomorrow...
    IronFord, brEad, NJ Don and 1 other person like this.
  26. Stogy
    Stogy
    @SDS...Big thumbs up...devilishly cool plate...;)
    brady1929 and Happydaze like this.
  27. 19Eddy30
    19Eddy30
    from VA
    Just saying ,,, Never built a 32 , But you did with Many Questions !
    "" If Not free, the alignment ""
    No fender's , Easy to set alignment
    30 mints or less , front with tape & straight edge, floor ... to Square , sting & little more time 30ish mints ..
    Would of been easer to set b4 Rad was installed ,
  28. SDS
    SDS
    Was a beautiful New Hampshire day today , so I took it for a little spin today before we loaded it on the flatbed... I am certainly I have a 350 gear in it versus the 373 I started with 20 years ago. My driveway is on a slight angle and it started to stall so I goosed the throttle a little bit and the back tures just lit right up. The power to weight ratio is incredible. That Comp Cams nostalgia 327 camshaft is so snappy.
  29. NJ Don
    NJ Don
    Scott,
    I'll bet that put a smile on your face!
    Stogy and pprather like this.
  30. SDS
    SDS
    It sure did, adrenaline rush that's still going.
    Stogy likes this.
