Built me a louver press.... and it works!
Discussion in 'The Hokey Ass Message Board' started by Kiwi Kev, Oct 2, 2006.
  1. OneRustedDodge
    OneRustedDodge
    You do absolutely amazing work!!
  2. 40Standard
    40Standard
    from Indy
    outstanding press
  3. rodknocker
    rodknocker
    If I was as smart as your pinky, I'd be way ahead of myself now.Thats engenious!
  4. deuceguy
    deuceguy
  5. tikidiablo
    tikidiablo
    from so cal
    I was checking out this thread this morning. When are you making up some more of them anvils? I still want one.
    D
  6. Jcar
    Jcar
    from fargo nd
    What is the throat depth on that thing? Is it deep enough to do all you want to do. Just curious,been planning to build one myself,yours has inspired me to get busy.
  7. The depth is 36" but that is not the limit because I built it so the dies can be installed in 4 different directions so the capacity is alot more than 36".
  8. ...the award for Coolest HAMBer. :)
    Yet another great thread from Kiwi Kev. Well done, mate. I think you're my favourite Kiwi in the whole wide world. ;)
  9. aceguy
    aceguy
    Very nice. A piece of art in itself!
  10. toddc
    toddc
    Awsome!!! What diameter ram is it running? What sort of line pressure?
    I'm a tool maker, but I've got no idea what tonnage would be needed to do the job.
  11. crook
    crook
    from Winder,Ga
    Yep, that is the ****!! I would be punchin' louvers through stuff that should never be louvered, I'd be louver freakin' crazy! I would size up everything I see by whether or not I could punch me a louver in it!!.....Dang this is an old thread, so you're probably well past this stage of excitement by now.
  12. cuznbrucie
    cuznbrucie
    That thing is ****s!*
    CB
  13. So Kev.
    How many have you punched with it now....
    That is the coolest machine I have ever seen..
  14. SOCAL PETE
    SOCAL PETE
    from Ramona CA
    That press is wicked...along with that Longboard collection. Damn!
  15. Von Rigg Fink
    Von Rigg Fink
    from Garage
    very cool, and great way to recycle an old machine into something new and useful.
    probably could do way more with it than just punch louvers.
    will you be offering pre louvered panels?
    I may want to have the rear panel below the rear window on my tudor done
    probably cost too much to have it shipped
    Nice lines too Skratch
  16. Stuff the louver press Kev, I wanna scope out that killer garage of yours !!!
    All those killer vintage longboards hanging from the rafters WOW!!
    Sano work on the press too !!
    Rat
  17. speedmetal
    speedmetal
    from houston
  18. HRK-hotrods
    HRK-hotrods
  19. attitude
    attitude
    from indiana
    Love the press..What tooling did you use to do the flamed recess panel? PICS?
  20. elrobo818
    elrobo818
    thats awsome dude... really resourceful.
  21. willie57
    willie57
    from wisconsin
    Give that man a Blue Ribbon
  22. at***ude.....This is a pretty old thread now, the flamed panel is bead rolled. If you haven't seen it already there is a thread called custom bead rolling ....lotsa pics that has alot of pics. Search for bead rolling and you will find it.
    LIFESTYLZ.... Don't know how many but it has been used steadily for 2 1/2 years now with no problems. That's Lucky Burton with the trunk panel for his A coupe.
  23. defender chassis
    defender chassis
    from WV
    Kev,
    Do you know what the pressure output on that pump is? I am in the process of putting together a lowbuck setup for louvers and a set of flair punches and am not sure how much of a hydraulic system I need. Any constructive help is apprecdiated.
    Thanks,
    Scott
  24. DBAG
    DBAG
    Cheers to that. Killer press..
    D
  25. I don't know any details on the pump, it is a 12v pump from a truck liftgate. The ram is 11" long x 3" ID with 1 1/8" shaft. I have seen a louver press with a Chevy power steering pump set up with an electric motor turning it.
  26. F&J
    F&J
    You don't need much preessure at the die. I just did some louvers in a big bench vise and did not need to overtighten the vice. the metal was 19ga
  27. defender chassis
    defender chassis
    from WV
    I have calculated that to punch a 4" louver in 20 ga metal it would take just under 6,000 lb of force at the die. This ***umes a non progressive cuttingh edge of 3.25 inches since the full width of the louver would not be sheared all at once and an ultimate strength of 60,000psi for typical steel.
    The reason I am concerned is because I picked up a set of the Mittler Bros louver dies and press kit minus the pump. I am trying to stay as low buck as possible but Mittler Bros wants to sell me a 10,000 psi pump. The problem is that the hyd cyl on my setup is much smaller that on Kevs.
    Anyway, by my calcs I do not need 10,000 psi but more like 3,000. Thats why I ask what Kevs 12v unit was putting out.
  28. aircoup
    aircoup
    way cool press dude only i wish id thought of it
  29. captainjunk#2
    captainjunk#2
    your a ace of a fabricator , that louver press is kickin shweeeet ,
  30. holyroller
    holyroller
    from KTOL
    Thats the coolest thing I've ever seen! I'd give my left nut for it, good work man.
