Bullet Centers??
Discussion in 'The Hokey Ass Message Board' started by Kruzer63, Mar 30, 2006.
  1. Kruzer63
    Kruzer63
    Hey guys I am wondering if any of you have made your own "spidercaps" for early ford wheels?? I have bullet shaped lug nuts, and want to put a bullet center cap in and so far have not found anyone that supplies a push thru bullet center cap for OEM wheels that fits the Ford wheels with the 5 1/2 Bolt circle. That is the wheels that have the larger hub center hole, 3 3/8ths i believe.
    Have any of you created something like this? I saw a 32 sedan that was copper in color on the cover of rodders Digest that had these bullet centers but i dont know if he had early ford wheels tho.
    Any help ?
    Thanks!!
  2. Rumplestiltskin
    Rumplestiltskin
    from OK
    I saw a tech article on this very subject in the tech archives. Some good methods in that thread.
  3. Kustom7777
    Kustom7777
    from Austin, TX
    i made a set.....get some center caps that fit through the center of a ford truck wheel..the kind that are cylinder shaped,,,,buy some of the tall chrome bullets,,,,,frank and carol from "chrome it" sell them (dont have their address here, but im sure someone does,,they are out of port trevorton, pa),,,,slip the bullets ovet the cylinder shaped center caps,,,grind away some of the chrome where the two meet so you can weld several spots around the perimiter,,,,spot weld them at about 3/4 inch intervals all the way around,,,,worked great for me,,,wish i had pics of mine,,but i didnt take any,,,,i did sell them to a hamber,,maybe they will see this and post some pictures..
  4. Squablow
    Squablow
    You want the 3 3/8" hole? A guy on eBay sells the bullet caps for 3 3/8" diameter wheels. I'm looking for the smaller diameter push through bullets, for 2 7/8" (approx) center hole. If you know where I can get some of those, let me know, please.
  5. Kruzer63
    Kruzer63
    Do you have a link for this guy?
  6. Squablow
    Squablow
    Sure
    http://cgi.ebay.com/ebaymotors/BULLET-OUTLAW-WHEELS-CENTER-CAPS-5-LUG-3-28-BORE-NICE_W0QQitemZ8051899625QQcategoryZ43961QQrdZ1QQcmdZViewItem
    Read through the description, he's selling them for some ugly aluminum wheels but they should work for your steel wheels too.
    Now, where were you finding the smaller diameter bullet caps? You mentioned that you couldn't find any for your wheel diameter. Does that mean you were finding them for other diameters? I need some for wheels with just under 3" diameter and I can't find anyone who sells them.
  7. RadirWheelsGuy
    RadirWheelsGuy
    Hey Guys, just letting ya know i have 2-15/16" and 3-1/4" in polished spun aluminum in stock for $68.00 a set plus shipping, I hate to say it but those chinese chrome bullets, you can watch them rust on your car!.
  8. Squablow
    Squablow
    Radirwheelsguy, are those the only sizes you have? 2 15/16 is still just a hair too big for my wheels. Or is it possible to modify them?
    I'd love to have some aluminum bullets on my car, they'll hold up a lot better up here in Wisconsin, plus then I can tell everyone that I have Radir's on my '55! I have to use the wheels that I have now, I made custom mini-trim rings to fit these wheels and they fit my car correctly, so swapping out wheels is not an option for me.
    Any suggestions? Can wheels be modified to accept the slightly larger bullets, or is that dangerous?
  9. yngrodder
    yngrodder
    Heres a set of radirs on 40 ford wheels. I need to buy two more,can I do that (or do I have to buy a set)?I bent two of them this winter, Mel[​IMG]
  10. Squablow
    Squablow
    How do the Radir bullets attatch? Are they push throughs, or is there a different method of putting them on the car? I want some, but size is an issure if there push throughs.
  11. yngrodder
    yngrodder
    they push though from the back. I think they make three different lengths these are the long ones so i could clear the early ford rear end.
  12. RadirWheelsGuy
    RadirWheelsGuy
    alot of guys have just had there wheel centers honed out to accept either size caps, its pretty expensive to have the dies made to make different sizes and there are so many millions of steelies out there with all kinds of center bores.
  13. Squablow
    Squablow
    Is honing the center of a steel wheel safe? If it is, I'm pretty sure I could make the 2 15/16" diameter bullets work. I'll shoot you a PM
  14. Kruzer63
    Kruzer63
    The ones i had found were, 3.1875, and 3.28 in diameter and i was lookin for 3.375 or closer to it.
  15. Kruzer63
    Kruzer63
    Did you buy them directly from Radir?? If those work on your 40 wheels they will work on mine as those wheels have teh same hub size as mine. Are they pricy??
  16. Bull
    Bull
  17. yngrodder
    yngrodder
    Yes I bought them from radir about two years ago if you just hold them up to the wheel they look like they would be loose but when you tighten the wheel the bullet tightens up pretty nice. the flange on the back of them has bumps that smash down when you put the wheel on and then when you take the wheel off next time just bend them back out and put them back on, I have had mine off and on a number of times with no problems. I am going to order some more to replace the ones I bent up.
  18. wheelman
    wheelman
    A co. called Star Wheel sells bullet lug nuts, bullet caps, bullet valve stem covers and several sizes of decorative bullets. They can be contacted at starwheel.com.
