bullit caps
Discussion in 'The Hokey Ass Message Board' started by fnmopar, Jun 3, 2009.
  1. fnmopar
    fnmopar
    Hey, Guys does anyone know where i can get a set of push thru bullet center caps for the dodge, the hole is 2 13/16 or is it safe to machine the hole larger to accept the common 3 1/8 Thanks
  2. turdchazer
    turdchazer
    from Spokane
    check Gambino Customs.
  3. Squablow
    Squablow
    The only sizes I've ever seen have been 3" and 3 1/8" and those sizes seem to be based on mag wheel openings and not stock steel wheel openings. I don't know that anyone makes push-through bullets for any stock steel wheels unless they just happen to have a 3" or 3 1/8" opening.
    I would not suggest cutting the hole bigger to fit the center cap, the wheel stamping has a raised lip around the center hole which is to prevent cracking from the lug nut hole out to the center hole. Some spider caps might be your best bet to get the look you're going for. They aren't dependent on a center bore size.
  4. bulletz
    bulletz
    from nz
    I have them to fit 2 13/16, they are 3" long or can be made longer if necessary
  5. BISHOP
    BISHOP
    You do great work. I looked at all your stuff.
  6. fnmopar
    fnmopar
    Bulletz ,how much for a set of them
  7. bulletz
    bulletz
    from nz
    PM for prices as there a quite a few sizes available and various materials...aluminum, chrome, copper, br***
