Technical Bump stop idea.
Discussion in 'Traditional Customs' started by jozw30, Feb 19, 2017.
  1. jozw30
    jozw30
    from Arizona
    IMG_0388.PNG 55 Olds 88 with a 9" and Speedway rear disc set up.
    The factor bump stop will hit the emergency brake cable.
    I wracked my brain trying to think of a bolt on solution, and all I can come up with is to fab a "bridge" over the cable. If this would work, I can shorten the rubber on the OE stop.
    As my sketch hopefully shows, I'd like to capture the bridge piece under the axle u-bolts. The bridge height is about 1 1/2".
    Is this not a good idea? If the curved area fits the axle nice it shouldn't affect the u-bolt to axle strength, correct?
    3340 likes this.
  2. okiewelder
    okiewelder
    from central Ok
    Looks line it will work for the intended purpose.
  3. Gahrajmahal
    Gahrajmahal
    I would say it depends on your horsepower.
  4. jozw30
    jozw30
    from Arizona
    Actually about 400hp 4l65E and 350:1 rear. If I keep at least the same amount of radial contact on the axle tube it should provide the same clamping force, no?
  5. hotroddon
    hotroddon
    It will work fine - been done before, variations on a theme Bump 1.jpg Bump.jpg
