1952-59 Ford Bumper question...
Discussion in 'Off Topic Hot Rods & Customs' started by dragonknucks, Jul 19, 2012.
  1. dragonknucks
    dragonknucks
    This may sound really dumb on my part, but will a 55 front and rear bumper fit on my 54? I found two nice ones that I can get for cheap. They are driver quality, and mine are painted. Also found many other pieces for 55s including really good back gl*** if anyone is interested. Thanks fellas!!
    Rocky
  2. 1 Ford fan
    1 Ford fan
    55 is wider. Might fit but won't look right....
  3. JeffB2
    JeffB2
    from Phoenix,AZ
    A measuring tape will tell the tale,you will no doubt need the 55's mounting brackets and if you can snag it the splash pan.The 54-56 Frames are probably the same width since all the suspension parts and rear ends interchange.52-54 rear bumpers are the same part number.You may be surprised "what fits" as you have seen 52-56 Fords running Merc clips and bumpers.I have seen 52-54 Fords with '55 grilles and the 55's full stainless that goes around the grille,you can even bolt in a '55 Plymouth grille in less than 1/2 an hour,as I said before a "measuring tape is your best friend" it's what "traditional" customizing is all about.
  4. Retro Jim
    Retro Jim
    I wish you lived closer because I would like to find better bumpers for my 55 .
    Jim
  5. dragonknucks
    dragonknucks
    I wish you lived closer cuz I would like a built 302.
  6. JeffB2
    JeffB2
    from Phoenix,AZ
