1952-59 Ford Bumper support identification.
Discussion in 'Off Topic Hot Rods & Customs' started by Jeff Norwell, Apr 4, 2023.
  1. Jeff Norwell
    Jeff Norwell
    MODERATOR
    I have a pair of these Bumper support pieces. they bolt from under the car to the outer corners of a bumper.I thought they were 57-58.. but are completely different... they have a longer reach....
    anyone know if they are from 55,56 or 59?
    Or....?????
    Thanks guys.
  2. evintho
    evintho
    I know they're not '52-'54. You can eliminate those.
    Jeff Norwell likes this.
  3. Texas57
    Texas57
    By "under the car" you meant what? I believe those bolt to the fenders, I'll look at mine. I believe those are the reason so many '57 fenders have a crown to them above the center of the wheel well..........if the bumper is hit hard enough, the movement, although sometimes temporary, transmits to the fender because of those braces causing it to "bow/bend" in the weakest area.
    lol, years ago, I read a post by someone who's bodyshop guy thought those "bowed fenders" were suppose to be that way because every '57 he ever worked on was that way. I had an extra set of fenders that had that bow on one of them.
  4. Texas57
    Texas57
    I looked. I misspoke. Mine do look like that, but they don't go directly to the fender. The 2 hole portion bolts on to where the splash shield behind the parking lights attaches to the long splash pan, which should then leave the single hole lined up with the bumper bolt.
    nosford, Jeff Norwell and jimmy six like this.
  5. Jeff Norwell
    Jeff Norwell
    MODERATOR
    They are Not 57 or 58
    I already have a proper set bolted to the splash box and then to the bumpers.
    So if not 52-54… or 57-58… 59?
    Or possibly 55-56?
  6. Jeff Norwell
    Jeff Norwell
    MODERATOR
    @bobss396 ?
    You own a 59…. Do you run these?
  7. Yutan Flash
    Yutan Flash
    from Gretna, NE
    I'd say 55-56.
  8. Dos Cincos
    Dos Cincos
    Correct. They mount to the front apron and bumper.
    Jeff Norwell and down-the-road like this.
  9. bobss396
    bobss396
    Front or rear? Definitely not the front of a '59. I'd have to look at the rear later on. I never had the back bumper off.
  10. Slicks
    Slicks
    from denison tx
    They look like the ones on my 56 wagon
  11. Jeff Norwell
    Jeff Norwell
    MODERATOR
    I think we found the answer. 55-56 front bumper supports....
    I only asked this question because I grabbed them to use on my second 57..... no fitment whatsoever ever...
    I have another proper pair... so I am good in that dept.
    I just wanted to identify for future use.
    thanks all
    ffr1222k and bobss396 like this.
  12. bobss396
    bobss396
    Good, I wasn't crazy about crawling under the car anyway. But my front brackets were m***ive by comparison to what you have. I had to make up a fender brace from some strap steel, that was 3/16" x 1" from Ace Hardware.
