Technical Burning oil
Discussion in 'Traditional Hot Rods' started by Harley Charley, Feb 6, 2021.
  1. Harley Charley
    Harley Charley
    I've got an early 392 hemi that was just rebuilt. It's got 1,200 miles on it and goes through a qt. of oil about every 200 miles? The smoke is really bad under heavy throttle! Any ideas?
  2. F-ONE
    F-ONE
    from Alabama
    "Rebuilt" can mean anything from spraying a dirty greasy engine with a half a can of Krylon to a 50K pro shop build.
    This is what comes to mind....
    Rings not "set". They may seat especially if chrome rings were used.
    Rings not installed properly...
    Do a compression check!!!!
    Valve guides worn or too much clearance.
    Oil or umbrella seals not not on the valves....
  3. jimmy six
    jimmy six
    Rings upside down can do it too...
    warhorseracing and Bbdakota like this.
  4. Doublepumper
    Doublepumper
    from WA-OR, USA
    Engine vented properly?
  5. Jalopy Joker
    Jalopy Joker
    post some pics of motor
  6. hotrodjack33
    hotrodjack33
    Were the heads re-machined, or just the bottom end rebuilt?
  7. A little more info will help for sure. Also, have you had any conversation at all with who ever you had do the work about it? I've always felt that's the best place to start when a problem comes up.
    warhorseracing, WB69 and squirrel like this.
  8. I agree with F-One, "rebuilt" can be a broad term. The condition you describe leans toward excessive oil entering the combustion chamber. Typical causes are too much piston to cylinder clearance, poor ring seal, valve guide issues,or a piston with a hole in it. Even chrome rings should have seated by now. Is this something new, or has it been consistent since the rebuild?
    F-ONE likes this.
  9. Pete1
    Pete1
    from Wa.
    Detonation at heavy throttle can also cause oil smoking and burning..
  10. WB69
    WB69
    from Kansas
    All of the above. Especially a conversation with the builder as Pist-n-Broke suggested would be a must if you know who it is.
  11. rockable
    rockable
    Lots of good points here. Do a compression check first and see if you can isolate it to one bore. Don't forget to unplug the coil and open the throttle when doing the test. You will get more accurate results that way.
  12. chevyfordman
    chevyfordman
    Those Chinese rings are no good
    koolbeans likes this.
  13. Glenn Thoreson
    Glenn Thoreson
    from SW Wyoming
    Bad gaskets on the spark plug tubes? I don't remember if they had 'em on the bottom. Three piece oil rings? They can catch on the cylinder edge and get damaged on installation. I don't know. After all I'm old so give me a break. :(
  14. lippy
    lippy
    from Ks
    You can pull the plugs, keep them in order with the cyls they came out of and see which ones are oily or not. Lippy
  15. koolbeans
    koolbeans
    Wuhon rings...very special...
    Sent from my XT1710-02 using The H.A.M.B. mobile app
  16. d2_willys
    d2_willys
    from Kansas
    What type of engine oil are you using for break in? Us old timers use Non-detergent oil for 500 miles, then change. Just make sure to use some sort of break in oil.
