Technical Butt weld cleco clamps?
Discussion in 'The Hokey Ass Message Board' started by chopolds, Feb 24, 2016.
  1. chopolds
    chopolds
    from howell, nj
    Yeah, I did a search but all that comes up is the HF wing nut clamps that have a gap in the **** weld.
    What I am looking for, and I HAVE seen them, is thin, two and four hole pieces of sheet metal (don't know if they are steel or alum.) that you use cleco clamps with, to secure and **** weld sheet metal with. The 2 holers looked a bit like a dog bone. I had found a rod shop that made them somewhere in AZ or NM, but can't locate the website again.
    Anyone familiar with them?
  2. Devin
    Devin
    from Napa, CA
  3. Texas Webb
    Texas Webb
    Those frame doors are cool also.
  4. oj
    oj
    You can drill an 1/8th hole in the middle of the seam, stick a cleco thru it and use a #10 washer on the back side, if you have enough flat area you can use a fenderwasher. Its rare you'll find enough flat area on a car. Anyway, thats what I use - those little washers you can buy to back up a 1/8th pop rivet work good.
    snopeks garage and loudbang like this.
  5. flt-blk
    flt-blk
    from IL
    I just drilled two holes in a piece of 1/2" sheet metal across the joint, nothing fancy in my garage. Once you tack on either side it can be removed.
    snopeks garage likes this.
  6. I have a Roper Witney hand held hole punch. It has a set of dyes from 1/16" up to 1/4". I make things like the Dog Bones often. The tool is like using a paper hole punch only for tin, S.S. and Alum. If your using 1/8" Cleko's you'll love how this works for 1/8" holes. Way better than any 1/8" drill bit.
    The Wizzard
    blackout78666 and loudbang like this.
  7. I like those, might need to make some.
    bct likes this.
  8. gimpyshotrods
    gimpyshotrods
  9. chopolds
    chopolds
    from howell, nj
    That's exactly what I saw, thanks Devin!
    I'd prefer to buy them, instead of make them, I dont' have lots of spare time, and also, I do a LOT of fabrication, and I'd need for them to be uniform, and precise.
  10. Buddy Palumbo
    Buddy Palumbo
    They're pretty damn cool. Never saw that style before - I'm really digging the 4-holer . Might have to put an order together.
  11. luckythirteenagogo
    luckythirteenagogo
    from Selma, NC
    loudbang and vintagedrags like this.
  12. gimpyshotrods
    gimpyshotrods
    vintagedrags likes this.
  13. Hnstray
    Hnstray
    from Quincy, IL
    Neither is the vendor's :D
    Ray
  14. gimpyshotrods
    gimpyshotrods
    Yeah, sure, but I get paid A LOT more.
  15. luckythirteenagogo
    luckythirteenagogo
    from Selma, NC
    My time isn't free either, but at $1 a piece (or $.50 a hole) plus shipping I can find a few minutes to whip up a stack.
  16. Hnstray
    Hnstray
    from Quincy, IL
    I figured as much...was just yanking your chain.....seeing if you were working...or screwing around on the I-net. Oh, wait.......time zone difference....you are on your lunch break :D
    Ray
  17. gimpyshotrods
    gimpyshotrods
    Off-campus lunch.
  18. Atwater Mike
    Atwater Mike
    I put 'frame doors' in my '32 frame under my last '27. Never saw them before, musta had 4 hours in 2 of 'em!
    I'd buy these for my present '27 Hiboy, just a sanitary way to go!
  19. [​IMG]With this tool and a Jump Sheer I bet I can make 20 4 hole pieces that all 80 holes line up exact to each other. Just saying. Plus it's a Kool tool.
    The Wizzard
  20. Devin
    Devin
    from Napa, CA
    I don't want to get in the make vs. buy debate, but these are super high quality and uniform so each one is absolutely interchangeable if you go back and forth fitting panels etc. Roseville rod and custom always has a presence at the Sacramento Autorama every year, so if you're ever there, it's worth pocking some up and saving on the shipping.
  21. gimpyshotrods
    gimpyshotrods
    If you want to make them, make them. It just isn't cost-effective for me. The small ones are $0.80/ea, and the large ones are $1.50/ea.
    If I keep all of my money, how are other people going to pay their bills?
    bct, 62hotcat, loudbang and 1 other person like this.
  22. jailbar joe
    jailbar joe
    I don't bother with **** clamps at all ....just **** the metal to metal then tack in a few places and just run the 1mm
    cutting disc thru the seam and weld....easy;)
    cad-lasalle likes this.
  23. You and I think a lot alike. However I've learned there are several ways to accomplish the same end result.
    The Wizzard
    Hollywood-East likes this.
  24. Hnstray
    Hnstray
    from Quincy, IL
    a REALLY well matched **** weld could conceivably be 'fusion' welded...no additional filler...with gas or tig........no gap needed.......minimal/no grinding and receptive to hammering the weld joint.
    yeah...I know...easier said than done.....but it is doable with care and some skill.
    Ray
  25. samurai mike
    samurai mike
    looks like you could grind up some old motorcycle chain to get the links.
    caseywheels, Hnstray and Baldies like this.
  26. Ray, now your talking. Once done it's easier than you think. No clamps, no Cleko's just tacks and weld it up. Both these projects were metal finished and only needed primer prior to paint. Like gimpyshotrods I get payed pretty well also. Every job brings it's own little needs with it also.
    P1010291.JPG P1010293.JPG P1010296.JPG Holy Smokes!!.jpg 02-23-12 001.jpg Not bad; 001.jpg
    The Wizzard
    loudbang, Hnstray and Hollywood-East like this.
  27. Hnstray
    Hnstray
    from Quincy, IL
    I did get an introduction to that with aluminum at Ron Fournier's metal shaping cl***es some years ago. After fitting the parts closely, Ron would clamp one end of a joint and gas weld the seam, moving one part in alignment with the other as he tacked the seam and then when fully tacked, welded it solid.
    We students had to replicate that. Opened my eyes to the possibilities and have done that on occasion with steel.
    Ray
  28. Hollywood-East
    Hollywood-East
    NCM_1127.JPG NCM_1107.JPG NCM_1094.JPG OK, I'll throw my .02 in, I just did two qtrs. On a off topic Camino, with nothing more than a couple self tappers an a harbor freight air saw an Zero warpage, an no fancy hoopla, I'm old an all but I Know someone "feels" me here, I did use a tool I came up with to Quench the weld, 8 1/2 feet of welding , An hour an a half to finish Note: per side...
  29. 1953 chevy
    1953 chevy
    from tucson
    Harbor freight sell them.
  30. cretin
    cretin
    I use the parent metal to make tabs, then you don't need anything else besides the cleco.
    If you're interested in seeing it, it's in my '54 chevy build that has a link in my signature. The explanation of the process starts at post #31 right at the top of page 2.
    Just another way to go about it.
