Technical Butt weld cleco clamps?
Discussion in 'The Hokey Ass Message Board' started by chopolds, Feb 24, 2016.
  1. chopolds
    chopolds
    from howell, nj
    True, but when you're doing major metal shaping, you need to keep fitting the panel to the car MULTIPLE times, and you really need to put it back on exactly where it was the last time, or you're spinning your wheels! Not talking just welding on patch panels here.
    62hotcat likes this.
  2. luckythirteenagogo
    luckythirteenagogo
    from Selma, NC
    I just looked at the Roseville ones on the link at in the beginning of the thread, and I do like them better than the Lazze version. Not only are they thiner, but they are cheaper as well. I'd just buy those as well.
  3. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    Here is how I like to make my sheet metal **** welds using Clceos:
    overlap the two pieces about 1/2"
    drill for clecos
    scribe the gap line with a Sharpy marker; cut away all the metal creating little tabs around each Cleco
    run the tabs through a bead roller to offset them
    tack weld / cut away the tabs /finish weld
    Hnstray likes this.
  4. cretin
    cretin
    My method is the same as @THE FRENCHTOWN FLYER , but I like to scribe the line in, and I use pliers to make the offset on the tabs.
  5. big duece
    big duece
    from kansas
    Wonder if the holes in a bicycle chain are 1/8" for cleco's? Might be able to grind the rivet heads off and get lots of links from an old chain... master_link.jpg
    caseywheels likes this.
