Butt welding panels you can't get behind
Discussion in 'The Hokey Ass Message Board' started by Joe Jackman, Mar 31, 2013.
  1. Joe Jackman
    Joe Jackman
    from SoCal
    Can you **** weld long panels that you can't get behind using TIG? I notice many people flange panels they can't get behind. Is flanging ever okay for outer body panels?
    http://www.youtube.com/watch?v=mSJUAT0H_Y0
  2. drptop70ss
    drptop70ss
    from NY
    why would you have to get behind it? you can tack weld something to the patch panel to pull it into position if needed. I would only flange a perfectly straight panel, anything with a crown can be ruined as the flanger will try to flatten out the panel.
  3. willys1
    willys1
    from South Ga
    The only issue with a flanged seam is water retention in the gap. If you can keep the water out you will be fine. If its for everyday use, i.e. rain, snow, salt I would advise against flanging exterior panels
  4. Joe Jackman
    Joe Jackman
    from SoCal
    "why would you have to get behind it?"
    To planish the weld so you don't need as much plastic filler.
  5. Joe Jackman
    Joe Jackman
    from SoCal
    If the vehicle sits in the sun and gets hot do you see the flanged area?
  6. rust
    rust
    Yes you will.
  7. David Totten
    David Totten
    Once you weld a flanged panel it becomes extremly stiff and almost impossible to straighten by any means.
  8. Joe ,
    Referring to the video you linked, the weld that's flanged is the top seam & a bit around the taillight. The rest are plug welds and **** welds. the lapped weld is so close to that rigid corner that there would be very little distortion from welding or sun movements. However at that point, wouldn't it have just been easier to do the entire 1/4 panel up to the windows and trunk
    Lets say his seam was mid panel on that quarter, not a good place for flanged lap.
  9. Joe Jackman
    Joe Jackman
    from SoCal
    "the lapped weld is so close to that rigid corner that there would be very little distortion from welding or sun movements."
    Good point. I missed that. Thanks for pointing it out.
    "However at that point, wouldn't it have just been easier to do the entire 1/4 panel up to the windows and trunk"
    That's what I thought when I watched it.
