butt welds
Discussion in 'The Hokey Ass Message Board' started by J53, Jul 1, 2011.
  1. J53
    J53
    from WI
    I've looked through the posts with pics of nice welds-nice work guys. My question is when you **** weld two pieces of sheetmetal, should the backside look just like the side you welded it from? Sometimes I get small spots where you can still see the edge of the metal, not enough weld penetration, right?
  2. tig master
    tig master
    from up north
    Lets see some pic's
  3. Correct, when you have full penetration you will not see the edge of the metal. When **** welding sheet metal together you should leave about a .030 gap between the two panels. This will insure you have full penetration. Otherwise when you grind the weld flat the spots that don't have 100% penetration it will crack.
  4. tig master
    tig master
    from up north
    What kind of welding?
  5. Leebo!
    Leebo!
    from Yale OK
    Hate to sound like a tard, but how exactly do you come up with .030 gap? that is roughly the thickness of what?
  6. bigbubba
    bigbubba
    Eastwood and Harbor frieght both sell some **** weld clamps that give you the proper gaps and hold the panels in place
  7. burl
    burl
    from Minnesota
    when i use my mig to **** weld panels i fit the patch tight to the opening with no gap.With the right heat setting and wire speed i get great penetration.There was a pretty good discussion on this on the metal meet forums most claimed no gap was the right method.When i learned to gas weld in high school we did the same.P***ed the bend test every time.
  8. 117harv
    117harv
    X2 for no gap.
  9. J53
    J53
    from WI
    That's what I thought. Sometimes I guess I get excited about how well it's going and start to rush. I guess I gotta just slow down. Thanks guys!
  10. badshifter
    badshifter
    You're still doing it. What are you welding? What are you welding it with? You can't get an answer without details.
  11. Goztrider
    Goztrider
    from Tulsa, OK
    0.030" is equal to a little less than 1/32"
  12. 49ratfink
    49ratfink
    the gap should be no bigger than a pubic hair. I always have a bunch on hand when doing any **** welding.
  13. Ebbsspeed
    Ebbsspeed
    Are you welding ****s, or welding with your ****?:eek:
