Hot Rods buying a chassis vs. having one built
Discussion in 'The Hokey Ass Message Board' started by pscalz, Nov 8, 2015.
  1. pscalz
    pscalz
    In my research for doing a 32 5 window coupe build I have found 2 builders who have built their own ch***is setups and sell them. However...since I'm new to this is it normal to have your builder build one or can I buy a ch***is setup (specs that I like) from another builder for my builder to use. I'm not trying to piss anyone off but I have brought up specs before to a potential builder about what I want and they don't seem to be getting it and at times It seems as if they just want shop hours to build one and charge me for. Thanks in advance for the feedback. I just thought I'd get an idea of what is the "norm"
  2. whoever is building your car should be able to work with a ch***is you got somewhere else. back when i was building hot rods for others i used whatever they brought....even if it was not MY first choice. of course i tried to steer them into what i wanted. i also had the option of not building the car
    my latest project is for me , and i'm making all the choices
    pscalz likes this.
  3. HOTRODPRIMER
    HOTRODPRIMER
    Truthfully,as many 1932 Ford ch***is that are offered you should be able to find exactly what you are looking for ready made.
    There are great builders here and many company's offering ready made dreams. HRP
    pscalz likes this.
  4. treb11
    treb11
    there are a lot more than 2 deuce ch***is builders out there. You should be able to find exactly what you want and have your builder complete it from whatever stage it arrives in. Some shops may not like using others work, as they want to avoid getting caught in a situation where there is a problem or having to re-do prior work to accommodate the customers wishes. a good builder will work with you to develop a detailed plan so you know what to expect at every stage of completion. Its your car and your money.
    pscalz likes this.
  5. HOTRODPRIMER
    HOTRODPRIMER
    BTW,there are some great frame builders in Texas. HRP
  6. wicarnut
    wicarnut
    The company's that build and sell a lot of ch***is cheaper are set up w/ fixtures to build as fast and economical as possible, therefore when you have changes, they are going to raise price to offset time involved, time and material charge would apply. There are many talented custom builders, will build anything you want, be prepared to pay accordinly. It sounds like your builder is trying to possibly help you save some $$$ OR you are dealing w/ wrong shop. Was in Tool & Die business for 37 years and we had our standard shop rates, at retirement, 2010, rates were $75/ $125/, if you told me how to do it and $150/ if you helped me. My point is if you are going to a PRO, w/ references, listen to his advice, an experienced builder will know his product from top to bottom
  7. thirtytwo
    thirtytwo
    I have a ch***is table to built something I am particular about having it a certain way , but as stated one offs take much more time than production I know only one 32 frame mfg that will deviate from what they normally offer , their rates are fair but it's time and material ...
    If you are going with a straight forward 32 , I would pic a over the counter frame with crossmember style and suspension type you want , but probably leave the motor mounts out so you can adjust and position your engine where you want it, if your doing a long motor like hemi olds cad ect , I would suggest pushing the front cross member forward up to a couple inches to make engine bay bigger
    Now if you want to do things like z the frame, narrow it , pinch rails , torsion bars, indy style suspension ,1/4 elliptics,or anything semi-exotic/ different your only choice is custom build buy a shop ,......BUT you have to also be confident in that shops engineering and problem solving ability... All shops are not equal...
    I've seen some sketchy stuff from shops on here and elsewhere ... They may also charge you while they are scratching their heads trying to figure things out !
    pscalz likes this.
  8. uncle buck
    uncle buck
    Some builders are hard to work with and some customers are hard to work with. As stated there are so many ch***is available for a '32 you could probably find what you want from a number of reputable ch***is builders. We don't know who "your" builder is so we can offer zero feedback on them. If they are so sure of themselves , what similar ch***is have they built in the past? Can they give you several references of their work? At the end of the day I see 2 choices here . You are paying the bill so you have the choice to choose what you want. The builder has the choice to work with you or decline doing the job.
  9. Blue One
    Blue One
    from Alberta
    If I were having a 32 built in Texas there would only be one shop I would consider.
    http://www.jalopyjournal.com/forum/threads/1932-pickup-rebuild-thread.970252/
    BRUCE'S ROD SHOP
    SPRING,TX.
    (281) 376-5932
    WWW.BRUCESRODSHOP.COM
    HAMB CHAPEL
    3nails+1cross = 4givin
    pscalz likes this.
  10. Ihave brought up specs before to a potential builder about what I want and they don't seem to be getting it
    Ok, what specs EXACTLY are you throwing out there that's not being grasped by car builders?
  11. oj
    oj
    I'd be getting another builder. You'll create a situation that your builder will blame all problems on the ch***is that he didn't build and the ch***is builder will blame all the problems on the car builder.
    The other possibility is you are giving wrong specs and your builder is trying to save your ***.
    shawnsauto1 likes this.
  12. pscalz
    pscalz
  13. pscalz
    pscalz
    Pretty much the feed back I get from builders is they don't like the idea and or it's not the style they prefer to use. For me structure and handling are key specs for a build not a "bolt on" approach that I've been getting. I hope that makes sense...
  14. pscalz
    pscalz
    Mainly...they don't like the idea of the pinched rails or a torsion bar setup.
  15. pscalz
    pscalz
    I do appreciate the feedback. This is all very helpful for me in narrowing down builders and learning about how to work certain aspects of a build. I'm not trying to say I don't think they would do bad work on a ch***is, but if I'm going to pay for work it might as well be work that I'd like to have for my own build and not take a cookie cutter approach to things.
  16. Mr48chev
    As others mentioned there are a number of first rate ch***is bulders in Texas. You might have to drive a bit to get to a few of them though.
    One has to wonder though if you are going in with "your specifications" and they are backing off or shaking their head, are your specifications that far off from the norm that they either call for a lot of extra work or a lot of one off work that differs from the shops standard procedure for building a 32 style ch***is. I got a quote from a Hamber with a shop in the Dallas area for a frame to go under my 31 Vic in the style that he builds and it was quite compe***ive and I figured that with the right timing I could work in a trip to visit the wife's family in Waco and Austin and come home with the new frame.
  17. Torsion bars aren't the "norm" and there are custom parts involved as well as a learning curve there. Unless the builder has done them before they probably wouldn't want to. Should you find a shop who's done them in a 32 frame before I'm sure they'd do yours too. Don't expect that to be cheap or comparable to a standard 32 frame
  18. thirtytwo
    thirtytwo
    I might add that , YOU should also not want them to do torsion bars if they don't want to ... Find someone with a couple it those builds behind their belt or someone smart that is excited about that kind of project ....
    I know Steve moal likes to use torsion bars .possibly roy fajsted jr..there are a few others .. But I can't think of them at the moment .. If you have very strict guidelines of how you want it done with lots of pictures even a race car ch***is guy might be able to help
  19. redo32
    redo32
    I think Steve Moal is doing torsion bar frames. Bet it's not cheap. So fill us in a little about your build and your budget & we might be able to help a little more.
    thirtytwo.....you type faster than me.
    pscalz likes this.
  20. He might find a guy willing to charge 100 bucks a shop hour to learn how to do them too.
  21. redo32
    redo32
  22. Tim
    Tim
    from KCMO
    image.jpeg Joe Kerr at joker fabrication would be my go to guy. Builds high horsepower cars running torsion bar suspensions.
    Jokerrfab.com I believe. Not in Texas but at this point what's another state for the right stuff
    kidcampbell71 likes this.
  23. pscalz
    pscalz
    Actually I was looking at the Moal ch***is....
  24. pscalz
    pscalz
    The Moal ch***is is what hits all the specs for me. It's in line with how I want my build to start but most important...function
  25. uncle buck
    uncle buck
    If you want a torsion bar ch***is , go with a builder with experience in them. Trial and error on your dime is never a good thing when you get outside a builders comfort zone
  26. Boatmark
    Boatmark
    Definitely not a budget set-up, but that's actually less than I would have guessed for a ch***is out of Steve Moal's shop.
    I can understand a shop hesitating to use a ch***is of unknown quality or craftsmanship. If there is a big issue down the road, it will be tagged to "the car built at XYZ shop", not the mystery ch***is builder. But coming out of a shop with Moal's history and expertise I think would be a safe bet for any shop.
    At the end of the day, it's ultimately your car and your checkbook. If a shop is unwilling or unable to build the car to your spec's, it's time to start interviewing different shops. Every build is not for every shop, and if the shop doesn't like the build, doesn't agree with the owners major decisions, or doesn't like the owner himself, the results are likely to reflect it.
    Good luck!
    pscalz likes this.
