Projects buying an ole can a beans:my 29 ford
Discussion in 'Traditional Hot Rods' started by Austin kays, Jan 13, 2018.
  1. :D Starter we don't need no stinkin starters.
    Real Model As use a crank. :D :D :D
    loudbang and brEad like this.
  2. dirty old man
    dirty old man
    Back when I was an 18 year old kid and had an almost stock "A" roadster and very little money, I had a starter go bad and the price of another was out of my reach at that time, so I bought a hand crank at a salvage yard and actually used it for awhile to crank that old "A". Tried to leave it where it could roll off if it was gonna sit overnight, but the rest of the day I used that crank.
    loudbang, pitman and Austin kays like this.
  3. I have cranked a few over the years.
    The slaughter house I worked at when I was in high school had an old John Deer that you started my pulling the flywheel. You got your hands out of the way as soon as you rolled it over, sometimes it would pop than run backward for a couple strokes.
    A kid I went to high school with had a T with V-8 60 in it. He had it set up for crank, I tried it once and just didn't have enough **** to get 'em done. But he used to start it that way once in a while just because he could. Tuned up if it rolled over and fired it would start. ;)
    loudbang and Austin kays like this.
  4. atch
    atch
    When I was a poor college student (over 40 years ago, and I'm still poor) there was a time when the only way I could start my car was to roll it down a hill. I couldn't afford groceries, much less a battery. Sometimes it was hard to find a parking place where no car could park in front of it on the downhill side.
    Austin kays, pitman and loudbang like this.
  5. Austin kays
    Austin kays
    Lol okay Benno. I'll have to get with ya this weekend at some point.
    Sent from my SM-J727T1 using The H.A.M.B. mobile app
  6. Austin kays
    Austin kays
    And yes Timm I tho k he has some wheels/roller tires I can borrow
    loudbang and Tim like this.
  7. pitman
    pitman
    Sounds like a good match! Quite a beak on the Crosley
  8. Be kind of a buzzard looking thing. LOL
    "Patience hell" :D
    loudbang and pitman like this.
  9. Tim
    Tim
    from KCMO
    Think you’ll want to run a generator or just hide a small alternator? Just thinking of bits and pieces that make it go and stay going.
    I found one I’m going to use that’s about the size of a large orange, just smaller than a softball for about $90
  10. sloppy jalopies
    sloppy jalopies
    and what alternator might that be, for $90 ? ...
  11. Austin kays
    Austin kays
    Gen for sure
  12. Austin kays
    Austin kays
    ct1932ford, kiwijeff, Stogy and 3 others like this.
  13. Austin kays
    Austin kays
    Also found out the flatty is bored .060 over! It's got a builders tag on it
    Stogy and loudbang like this.
  14. Tim
    Tim
    from KCMO
    @sloppy jalopies Do a search for Suzuki alternator, it’s got a funny name like nipson denso. They were also on geo’s but I’m thinking the geos got a flat serpentine belt and the Suzuki has a v belt.
    One wire internal regulator and readily avalible. They are super small and have a neat finned case similar to some mopar alternators
    brEad and loudbang like this.
  15. Austin kays
    Austin kays
  16. Tim
    Tim
    from KCMO
    I’ll let him get you guys up to speed and tell the story but I’ll leave this little teaser.
    Nothing’s getting in his way today!
  17. nice to finally see some real progress on that project
  18. Austin kays
    Austin kays
    Well boys the ole can us sitting 3 1/8th lower now!! That channel is done! When the better half gets home I'll have her take a pic of me next to it for comparison [​IMG][​IMG][​IMG]
  19. Austin kays
    Austin kays
  20. saltflats
    saltflats
    from Missouri
    I bet I have stomped around that town as a kid a time or two.
  21. Austin kays
    Austin kays
    Well I'm just playing now haha still have to channel the cowl[​IMG][​IMG]
  22. Tim
    Tim
    from KCMO
    You left out the part where you blew the power in your garage, and undeterred started again in the morning with a big extension cord from the living room.
    Nothing’s stopping him this weekend!
    Make sure to keep something over that manifold when there’s not a carb sitting on it. Last thing you need is something sneaking down there :S
  23. Austin kays
    Austin kays
  24. Tim
    Tim
    from KCMO
    I Made a block off plate from thick cardboard and bolted it on for mine. Seems to be holding up so far :)
  25. Austin kays
    Austin kays
  26. Austin kays
    Austin kays
    Okay fellas what's the length of a stock model A driveshaft/torque tube?
  27. Austin kays
    Austin kays
    Well there's been a bit more progress in the mock up area if my build. @Tim hooked me up with some 29 A seats that have really good bones. Also some 1929 head light buckets. (Still need the mounting brackets for those bad boys) the new sub rail is bolted down to the frame. So now it's time to start making a floor for it this afternoon after work. Maybe a little later on in the week I'll weld the motor mounts and cross member in and get the motor and ****** set.
    Oh and I might have the best neighbor there is came home to some steel wheels I need for the A bone sitting behind my chebby! And a couple ole spoke.wheels with decent rubber for mock up[​IMG][​IMG][​IMG]
  28. Tim
    Tim
    from KCMO
    Yeah you couldnt have gotten any luckier with your neighbor situation. Can wait to see it sitting with the nose down, the grill cut down, and the motor in the correct place
    loudbang, JOYFLEA and Austin kays like this.
  29. Austin kays
    Austin kays
    Well 100% not a carpenter but she'll work lol man its looking like something :) now to weld some angle in for it to sit on[​IMG][​IMG][​IMG]
  30. Austin kays
    Austin kays
    Lucky to have my lady out there do***enting my build. Got most of the sub rail welded in rather than tack welded in also got the angle for the floor welded in tomorrow I'm going to cut and mount the middle floor and maybe try to m o c k the motor up closer to where it's going to live[​IMG][​IMG][​IMG][​IMG][​IMG]
