Technical Bypass fuel filter help......
Discussion in 'The Hokey Ass Message Board' started by c-10 simplex, Jun 13, 2019.
  1. c-10 simplex
    c-10 simplex
    Need part #'s and specs for this kind of filter:
    Please list the return orifice size if any, and corresponding part #'s.
    If no orifice size, then please also list corresponding part #'s.
    Also, please list where you found the specs.
    What i'm trying to do is experiment with pressure, specifically lowering it. Yes, i do have a nice billet holley regulator, but i want to try a filter first----much lighter, simpler etc.
    Thanks.
  2. 19Fordy
    19Fordy
  3. squirrel
    Beanscoot and c-10 simplex like this.
  4. 325w
    325w
    Early Pontiac and later keeps use it
  5. kursplat
    kursplat
    can't remember used on which, 6pak or hemi cars. maybe both?
  6. tb33anda3rd
    tb33anda3rd
  7. oldiron 440
    oldiron 440
    Mopar used them in the eightys, M and J bòdys.
  8. c-10 simplex
    c-10 simplex
    i think .057 is close enough to .060, which is, i think, what the general consensus of what the orifice is on these filters?
    If i need more pressure drop, i figure i can just drill out the hole little-by-little as needed?
    i've got an electric pump that's advertised as 4.25 -6.25 lbs., and with gauge it's 3-5.75 lbs. on my setup. i'm just trying to get the idle pressure a little lower and don't care about cruise pressure because i rarely rev above 3000 for any length of time. Quadrajet. 2.56 rear---hence the lower rpms.
