Hot Rods C 4 Blues
Discussion in 'The Hokey Ass Message Board' started by CDOGV8, Mar 11, 2018.
  1. CDOGV8
    CDOGV8
    Just put the C4 trans back in my coupe after the torque converter sent metal filings through the box and started to lose gears etc. Now the rebuilt trans has no oil flowing through the cooler. I have only done about 10 miles in it, would love to fix it without removing it from the car as it's a major , any thoughts would be greatly appreciated.
    Pete
  2. tfeverfred
    tfeverfred
    When you fixed the transmission did you replace the cooler?
  3. CDOGV8
    CDOGV8
    No cleaned it out but there is no oil even flowing to it
  4. R Pope
    R Pope
    C4 has very limited oil flow to the cooler at best. I had one that only flowed any at all, at highway speeds. Ran like that for years.
  5. CDOGV8
    CDOGV8
    Nope this trans had good flow before with the first rebuild and was told no oil will be getting to the back of the trans
  6. Johnboy34
    Johnboy34
    from Seattle,Wa
    Sounds like it could be the seal rings on the pump snout. It would mean removal and pull pump. Who rebuilt it? They could have broke when installing the pump or converter. Not what you wanted to hear I'm sure..
    Sent from my SM-G900V using The H.A.M.B. mobile app
