Hot Rods C-4 TRANSMISSION HELP
Discussion in 'The Hokey Ass Message Board' started by V4F, Jan 29, 2015.
  1. V4F
    V4F
    from middle ca.
    does anyone have specs on a ford c-4 ? length , weight , etc ........... thanks .. steve
  2. jseery
    jseery
    from Wichita KS
    Transmission around 110 lbs + converter around 30 lbs. Length 30 1/4 to 30 1/2 face of bellhousing to end of tail housing.
  3. V4F
    V4F
    from middle ca.
    thank you . ................. steve
  4. V4F
    V4F
    from middle ca.
    does anyone know the final gear ratio on a c-4 ? is it 1-1 or overdrive ? ........ thanks .. steve
  5. Baumi
    Baumi
    Final drive is 1:1. It´s a 3speed.
  6. Baumi
    Baumi
    a good ******, easy to rebuild too.
  7. V4F
    V4F
    from middle ca.
    do they make an O.D. ? ............... thanks .. steve
  8. jseery
    jseery
    from Wichita KS
    AODs are the over-drives, C4 & C6s are both 3 speed with final drive 1:1. You can add an overdrive, but it's not cheap!!! GearVenders I have one on a C6 in a 65 Comet Cyclone.
