C 4 transmission yoke and 59 Ford driveshaft question
Discussion in 'The Hokey Ass Message Board' started by 327Eric, Aug 23, 2012.
  1. 327Eric
    327Eric
    I'm in a jam with my landlord and have to make all my cars run and drive on the quick. I have a 59 Ranchero, that I installed a 289/c4 out of a 65 mustang into. I need a driveshaft and yoke for it. I have the original fordomatic yoke. Will that work? Also, is there a junkyard driveshaft anyone has used for this combo?
  2. Take the original driveshaft and get it cut to length then take a junkyard youl for a C-4 and put it on the original driveshaft with a ******* joint.
  3. paleot
    paleot
    from louisiana
    I put a c4 in my 53 customline, The shop that built my shaft did not check to see if a crossove ujoint was available I had to buy a 1310 weld in yoke from drive train specialtys works like a champ.
    Luck Tony
