c-notch or z???
Discussion in 'The Hokey Ass Message Board' started by subrock, Mar 4, 2004.
  1. subrock
    subrock
    I want to be able to drop 48 chevy pickup to the ground on bags but I have a question about what frame modifications are necessary to get it that low in the back. I am thinking about going 4 link and I may have found a kit, and I am looking for bags currently. do I have to C-notch or Z the frame to get it that low. If I do C-notch or Z what problems with body fit does that bring up? I plan on tubbing the rear wheels too to get some bigger tires in there.. would that accomodate the new kickup?
    thanks [​IMG]
    ian
  2. Tim
    Tim
    from KCMO
    hmmm, get the right height tires then sit the frame on the axel with no leafs oranything.
    realy close?c notch
    not at all? Z
    just a thought
  3. kyle paul
    kyle paul
    from sac
    i would c notch it.then you ll have less work to do on mounting the bed.kyle
  4. subrock
    subrock
    thanks guys
    ian
  5. gotcha
    gotcha
    from Sanger, TX
    You may be able to get by with just a c-notch, depending on wheel/tire size...If that doesn't work, then go with a small step notch and all you will need is to trim the bed for clearance...
    JP
  6. Flipper
    Flipper
    from Kentucky
    I'm sure it's been beat to death, but what is the strongest way to reinforce a c-notch and it still look good? How much beef is needed?
    I have seen F'd up minitruck frames that weren't done right, but I don't know what the truck went through to bend 'em up.
  7. gotcha
    gotcha
    from Sanger, TX
    I use 3/16 plate on all my notches, and have never had anything bend...I used 1/4 plate when I first started building cars/trucks, and that was a little overkill...
    JP
