Technical C10 Trans pan replacement
Discussion in 'The Hokey Ass Message Board' started by Andrew McDonough, Nov 30, 2014.
  1. Andrew McDonough
    Andrew McDonough
    Hi everyone, I was curious if anyone knew the easiest way to get the trans pan of a 1974 C10 with a TH350 transmission. Two of the bolts are covered by the trans crossmember and that makes them basically totally inaccessible, it looks like I'll have to unbolt the trans from the crossmemeber and jack up the trans slightly. Was trying to avoid that but I will if I have to, thanks.
  2. greybeard360
    greybeard360
    The trans mount probably needs replacing anyway. They are real close anyway, but a collapsed mount makes it worse.
  3. 327Eric
    327Eric
    you nailed it.either move the trans crossmember, or jack up the ******. no real trick to make it easier, although you could remove and trim the crossmember for the next time
  4. squirrel
    is that the crossmember that's held in place with 24 bolts?
  5. King ford
    King ford
    from 08302
    Torch......in the fuel tank
  6. I used to maintain a fleet of these things and was always able to get those 2 bolts with a 1/4" drive wiggler socket.
  7. OLDSMAN
    OLDSMAN
    Like in the previous post use a 1/4 drive wobble and the 1/2 inch socket and they will come out. It is close but it can be done
  8. Andrew McDonough
    Andrew McDonough
    Thanks for the advice guys, going to pick up some wobble extensions tonight.
  9. squirrel
    probably the easiest thing to do is take out the two bolts that hold the mount to the crossmember, and jack up the transmission a ways...
  10. 57 Fargo
    57 Fargo
    what squirrel said, also makes it easier to wrangle the pan full of atf out of there
