Technical C2AE interceptor
Discussion in 'The Hokey Ass Message Board' started by SwaggerJacker, Jun 2, 2025.
  1. SwaggerJacker
    SwaggerJacker
    Guy is selling this on FB local to me!! It’s looks like a boat motor can I still use it? Have a 272 in my 55 now but wanna build one with some power and a aod trans. Guy is asking $750 but is open to offers. What’s a good price to pay? Would this even work for my 55 fairlane. Thanks for any help
    WC145 and chryslerfan55 like this.
  2. As the fine print in rules clearly states, pictures or it didn’t happen.
    WC145 likes this.
  3. SwaggerJacker
    SwaggerJacker
    Pic
  4. SwaggerJacker
    SwaggerJacker
    Do t know why you would need a pic for everything but here you go
  5. y'sguy
    y'sguy
    from Tulsa, OK
    A C2AE is a 292cu inch, and a good one to use and or rebuild.
    One question to confirm is the rotation of the engine, as some marine engines rotate in the opposite direction.
    Marine engines are generally clean, but can also be rusty in the not-so-usual places or worse, busted from freezing. If you are going to change out to a new cam and lifters when you rebuild, you can still use the main engine if it is reverse rotation ,you will just have to change out a bunch of stuff. BUT, you would probably want to change out to new stuff anyway to some degree.
    C2AE is what I have but fitted with a 312 crankshaft makes it a stoker. Lots of grunt with the right cam and the usual fun power adders. 750 seems a bit high, but I would have to see it run really well to get comfy with that price.
  6. Fordors
    Fordors
    Do you live anywhere that the engine might have been used in salt water? If so there could be water jacket corrosion that may be severe.
    seb fontana and chryslerfan55 like this.
  7. y'sguy
    y'sguy
    from Tulsa, OK
    Yah, I forgot to say if it has been used in salt water it's just better to p*** on it.
  8. williebill
    williebill
    Are 292s hard to find in your area?
  9. seb fontana
    seb fontana
    from ct
    Salt water damage can continue long after use. I knocked the loose chunks out and de-rusted with vinegar and a battery charger, I think I threw some Coca Cola in too. Some holes into cylinder so block is junk. IMG_0540.JPG IMG_0546.JPG IMG_0548.JPG IMG_0556.JPG
  10. The carbs are cool.
    Truckdoctor Andy likes this.
  11. The idea of a picture is so your fellow H.A.M.B. ers can help you find the answer to your question.
    Oneball and Sharpone like this.
  12. drtrcrV-8
    drtrcrV-8
    seb fontana : That poor little Crosley...
    seb fontana likes this.
