Technical C4/Aod
Discussion in 'The Hokey Ass Message Board' started by 53Mercuryvert, May 9, 2025.
  1. 53Mercuryvert
    53Mercuryvert
    If speedometer is indicating faster than actual speed, do you go up or down with tooth count
  2. FrozenMerc
    FrozenMerc
    You need to slow the cable RPM down, so up in tooth count.
    38Chevy454 and jaracer like this.
  3. Relic Stew
    Relic Stew
    from Wisconsin
    Standard speedometers are designed to display 60 mph at 1000 rpm. Calculate driveshaft rpm from gear ratio and tire cir***ference, then you'll have the ratio you need in the speedometer drive gears.
