1952-59 Ford C4 to AOD bellhousing
Discussion in 'Off Topic Hot Rods & Customs' started by Cody RRcc, Jul 23, 2023.
  1. Cody RRcc
    Cody RRcc
    I recently picked up a 54 customline with a 312 and a c4.
    The ****** has a Y block bellhousing. Can this bell housing be used for an AOD install? Or will I need an adapter to run the AOD.
    Any info is appreciated.
  2. tcoupekyle
    tcoupekyle
    Need an adapter. The bellhousing on a aod isn’t removable like the c4
    JeffB2 likes this.
  3. JeffB2
    JeffB2
    from Phoenix,AZ
  4. Paul2748
    Paul2748
    The adapters for a C4 to a YBlock that I have seen have a new bellhousing specifically made for the conversion. Won't work with an AOD.
    jimmy six likes this.
  5. JeffB2
    JeffB2
    from Phoenix,AZ
    Here is the straight answer, I asked the Chat Tech to confirm, the only difference is in the flexplate see the notes. https://www.transdepot.net/Ford-Y-Block-to-AOD-Adapter_p_746.html
  6. JeffB2
    JeffB2
    from Phoenix,AZ
  7. JeffB2
    JeffB2
    from Phoenix,AZ
    Notice the prices in these articles ? WOW ! Great example of inflation, I think we know the cause.
    orangedog likes this.
  8. TomDobbs
    TomDobbs
    Now, now, Jeff. We mustn't jump to conclusions! :rolleyes:
  9. T Hudson
    T Hudson
    Corporate greed, screw the worker, screw the consumer and pay the share holders. Has little to do with whose in DC.
  10. Paul2748
    Paul2748
    The Flat-O-Matic kit includes a replacement bellhousing, it does not use a flat adapter as shown above.
  11. nosford
    nosford
    Yes, the Gene Benson kit sold as Flat-O-Matic has a custom bell housing, flexplate, crankshaft adapter, and a starter nose with a new bendix. Here are some photos of a C-4 with a 292 installed using one of Gene's kits. Like has been said, a C-4 has a separate bell housing, AOD has a one piece case with bell housing cast on, not removeable. 223400948_4260949143962231_8125775385373014118_n.jpg 219617042_4260949120628900_6875846900023448780_n.jpg 218917985_4260949147295564_1864555653868149413_n.jpg
    56longroof and down-the-road like this.
