1952-59 Ford c4 to flatty
Discussion in 'Off Topic Hot Rods & Customs' started by bigshawn, Aug 5, 2012.
  1. bigshawn
    bigshawn
    So you guys that have done the c4 to flatty swap how happy are you with it and how was it to do? I went on a long trip last weekend about 130 miles each way on turnpike and the old 2 speed ford o matic just wasnt happy howling the whole way. Worst part was not being able to keep up with my buddies ,they thankfully slowed down for me, but I know they wanted to tear it up a little . what am i in for since I have never done this before thanks guys oh by the way I have a stock rear and my flatty is a pretty stock 52 and 6volt
  2. Ole don
    Ole don
    A C4 conversion will do nothing for you. Both transmissions are 1 to 1 in top gear. You need a different rear ratio, or an overdrive.
  3. bigshawn
    bigshawn
    So I would be better off changing out to a 8 or 9 inch rear end ?
  4. JeffB2
    JeffB2
    from Phoenix,AZ
    Or instead of the C4 use an AOD that has overdrive the conversion kits are "almost" the same,the best donor AOD is 1988-93's as they are non-computer and have the later upgrades to be reliable.
  5. paleot
    paleot
    from louisiana
    I just put a C4 in my 53, I dont know the gear ratio of the rear end. I wish I had done a aod it is definitely not a highway cruiser.
    Tony
