C4 tranny question
Discussion in 'The Hokey Ass Message Board' started by devilhead, Jul 23, 2007.
  1. devilhead
    devilhead
    from new jersey
    Trying to work out the bugs on a recently purchased '53 ford. It has a C4 tranny 3 speed auto out of an early 70's torino. I am having two problems. the first isunless I manually shift through the gear with the ratchet shifter, it really doesn't shift. It feels like one gear. The other prblem is once I get it up to speed while just depressing the gas pedal enough to cruise at a steady speed it makes a winding sound. If I increase my speed it goes away . Anyone got any ideas what the problem could be ?
  2. fordf1trucknut
    fordf1trucknut
    Is the vacume line from the intake hooked to the modulator on the transmission?
    Or maybe the modulator is bad or out of adjustment. (they are pretty easy to adjust/replace).
  3. Sour Kraut
    Sour Kraut
    Check the shift pattern, early 60's C-4s had a P R 2 D 1 pattern.
    The trans. might be older than the car!
