C4 trans help
Discussion in 'The Hokey Ass Message Board' started by Yelpat, Mar 17, 2013.
  1. Yelpat
    Yelpat
    from Arkansas
    Just got 39 ford pick up project. Still has original frame
    With front wishbones. Will a long tailshaft c4 trans fit?
    It will be. Behind a 302
  2. big duece
    big duece
    from kansas
    Didnt the 39 have a closed driveline? What drive line/rearend do you have?
  3. Yelpat
    Yelpat
    from Arkansas
    Using a ford 9 inch rear end and will custom cut the driveline
  4. George/Maine
    George/Maine
    As far as I know there is only one tail shaft length.
    I have a c4 in my 39 car and with a 8" rear, I had the have a driveshaft made up,you may get lucky and find one the correct length if ever one is to be had.
  5. big duece
    big duece
    from kansas
    I would mock up a sbf block, and from back of block to trans mount and see what options you have for c4 tailshafts. I have a short c4 setup if you need a measurement. Driveshaft fitment would be last.
  6. Yelpat
    Yelpat
    from Arkansas
    That's what I was thinking but thought someone may have
    Tried this combination before. I have the longtailshaft tranny
    If it will work if not . I'll be looking for a short tailshaft
  7. George/Maine
    George/Maine
    I bought a Chassic Engeering trans kit,and the trans I used was from a 81 Granada.
    The plate had holes for the trans mount were about 2" off , I Drilled new holes.
    There shouldn,t be any other problem.
    I have a 8ba 49-53 flathead with c4 with Lockar shifter.
  8. AnimalAin
    AnimalAin
    When my coupe had a C4, it fit in without much drama. The AOD in there now is a different story.
  9. 40FordGuy
    40FordGuy
    Ditto,...George / Maine The Chassis Engineering kits are just the ticket,.......I used the c4 kit, for use with the RUG 3 speed top loader, drilled holes where needed, and voila !!
    Happy Roddin" 4TTRUK
  10. Yelpat
    Yelpat
    from Arkansas
    Thanks for the info
