Technical C4 trans in 54 ford
Discussion in 'The Hokey Ass Message Board' started by 54shoebox, Aug 21, 2018.
  1. 54shoebox
    54shoebox
    putting a C4 trans in my 54 mainline and would like to keep using the speedometer on the dash. what speed cable am i going to need to use to make this work? is there an adapter?
  2. You probably won't find a 'off the shelf' cable for this, but most any speedometer shop can make one up for a reasonable charge.
  3. oldsman41
    oldsman41
    I did this in a 55 had to use the local speedo shop. Long time closed now.
  4. squirrel
  5. 54shoebox
    54shoebox
    will the 64 ford plug right into the back of the gauge?
  6. squirrel
    if it has the standard 5/8" thread. Look at the speedo, does it look like that cable will fit?
    (btw looking up cables for 49-54 ford cars, they all seem to have that standard end at the speedometer)
  7. IIRC, Ford changed the speedometer nut size in the early '60s which is why you can't find a OEM unit that works.
    I did a 351W/FMX swap into a '56 Ford and was unable to find a factory speedo cable with the right ends on it.
  8. Jimmy2car
    Jimmy2car
    from No. Cal
    An easy way to get a cable built is to contact your local Law enforcement agency & ask who does the speedo calibration. The same people will likely make up cables for you.
    In Norcal, I used the same shop that does Hiway Partrol work & he made up my cable for my 32. Gear Vendors OD to Autometer Speedo. 50 bucks & a perfect fit.
    Jim
  9. RmK57
    RmK57
    I used the original one from my 57 into a c-6.
  10. squirrel
    they changed in 49, and cables are listed that fit from 49-1960 models.
    I'd get under there and look at the speedo and if it measures 5/8" on the threads, buy a cable and see if it fits. you can return it if it doesn't fit, if you don't mess it up.
  11. 54shoebox
    54shoebox
    thats the one you posted from oriellys fits most of those years?
  12. 28 Ford PU
    28 Ford PU
    from Upstate NY
    This is one of our alliance members. I have no experience with them but it looks like a winner to me.
    Speedometer and Alternator Service Co.
    449 E. Kiowa St.
    Colorado Springs, Colorado 80903
    (719) 632-3165
    rusty@speedoservice.com
    warhorseracing likes this.
  13. RICK R 44
    RICK R 44
  14. evintho
    evintho
    Jimmy2car, do you have a name and location for that shop? The only speedo shop we had in Sonoma County shut their doors a couple of years ago.
  15. Hnstray
    Hnstray
    from Quincy, IL
    I have some sort of NOS aftermarket cable adapter intended for that era Ford. I will post a photo of it, but it will be later in the day tomorrow before I can do that. It may, or may not, have any relevance to this matter, so, if you find a source for some thing that works, go for it. In any case, I need to identify the purpose my of part and find a home for it.
    Ray
  16. squirrel
    The one I linked to goes back to 1957, but keep in mind there are two ends to the cable...the top end has to fit the speedometer, the bottom end has to fit the transmission. They changed the transmission in the later 50s, but the speedo stayed the same.
    You have the car, you have the transmission, you can look at what the cable has to connect to, and see if it will fit.
    I'm not as familiar with Fords as I am with Chevys...so I don't know for sure that it will fit..but I'm about 90% sure.
  17. paleot
    paleot
    from louisiana
    I have a c4 in my 53, I am using the stock cable. By the way I don't know if anything on the trans has been modified it is a speedway kit
  18. Fomoco998
    Fomoco998
    A relative has a 53 Merc with a C-4 and we just used a early Mustang cable .It had the 5/8" at speedometer head . Just need the gear match for rear ratio .
  19. SEEKONK JIM
    SEEKONK JIM
    2 other ways to fix this....1...buy a g.p.s...unit......2 if you have a tack you can mark the speed on it....hight of tire...rear gear ratio....r .p.m....will give you speed at that r.p.m.. i use a dream wheel from mark williams gear co...
  20. 28 Ford PU
    28 Ford PU
    from Upstate NY
    I use a app on my phone I think it’s called “speedometer” or “waze” gps has a speedo in the lower left corner but it’s a little small for my old eyes.
  21. 28 Ford PU
    28 Ford PU
    from Upstate NY
    Like seekonk is saying. You can get a cable to go between the transmission and speedo but if your tire size, gear ratios don’t match it’s not going to be accurate. Mines not that’s why I use the app.
  22. lowrd
    lowrd
    Look up Hotrodprimer here, I believe he has a C-4 in his wife's 54 wagon.
  23. junkyardjeff
    junkyardjeff
    I used a 65 galaxie cable in my 55 that has a C-4
  24. ffr1222k
    ffr1222k
    Hotrodprimer has a T-5 in the 54 wagon.
  25. Primetime 45
    Primetime 45
  26. Jimmy2car
    Jimmy2car
    from No. Cal
    Evintho
    Sorry, but the guy I used retired. The place is now a carb shop in Marysville, CA
    Jim
  27. morac41
    morac41
    If your handy with propane torch, just cut the two in half and silver solder to the right length...done this several times....never failed....
  28. JeffB2
    JeffB2
    from Phoenix,AZ
    Go to Pep Boys and ask for an ATP Y-801 it will have the correct ends. Under $20
