If I remember right the C4 takes around 9 qts dry.And most of that is in the Torque converter.How many Qts when changing out a filter?
Fat you nerd!! hahaha!! Its a 64 C4 stock pan..I dont want to over fill it before starting it up...It would be good to know..but i can figure it out...
1965 Motors manual says 3 quarts. Then go thru the hot check level ground shift thru the gears routine.
