c6 fluid level problem
Discussion in 'The Hokey Ass Message Board' started by billy zz, Jan 7, 2012.
  1. billy zz
    billy zz
    the filler tube on my c6 transmission has been cut shorter
    and that makes the dipstick readings totally inacurrate.
    i recently had a hose to the trans cooler become loose.
    and lost a lot of fluid.
    how do i figure out what the proper amount of fluid to add is?
    once i get it filled correctly i can put new markings on my dipstick.
    i am thinking maybe pull the pan and empty the ****** of fluid (excepting the torque converter)
    and then adding the correct amount. (whatever that is)
    thank you.
  2. Chemin
    Chemin
    If you know how much the tube has been cut just make a mark farther up on the dipstick by the same amount.
  3. Chemin
    Chemin
    Failing that, I just measured mine and the tip of the dipstick sticks out 2 3/4" from the o-ring on the tube.
  4. billy zz
    billy zz
    now THAT is useful info!
    could you do me a favor and measure how long your dipstick tube is?
    then i could simply measure mine and adjust accordingly then cut my dipstick at the right length.
    does that make sense?
  5. Chemin
    Chemin
    The tube itself is right about 18" long
  6. damagedduck
    damagedduck
    from Greeley Co
    i see you got your answer,-chuck
  7. billy zz
    billy zz
    you guys rock
    i measured mine as closely to the way you did yours and came up with 14 "
    then added the 2 3/4
    and that got me in the ballpark
  8. Chemin
    Chemin
    Great! Glad to help out.
  9. One thing billy , I would be alittle concerned that the dipstick goes x-amount of distance deeper than it was designed into the internals ... you probably should also cut your dipstick a like amount.
  10. billy zz
    billy zz
    i have one more favor to ask of you.
    do you have a pic of the business end of that dipstick
    maybe against a measuring tape?
    i would like to see where exactly on the stick the add and full lines are so i can mark mine. (it got cut off on that end.)
    i hate guessing where my fluids are at.;)
    thanks buddy!
  11. 40FordGuy
    40FordGuy
    Or,...dig one out of a wrecking yard, if you know what the C6 came out of,.............
    4TTRUK
  12. Chemin
    Chemin
    How's this for detail?
  13. billy zz
    billy zz
    you rock brotha!
    thanks so much.
