I am seriously considering swapping out my C6 for an AOD on my Model A. I have a question about the differences in the lengths of these transmissions. I am not so much concerned about overall length as I am the length from the block mating surface to the trans mount pad. Is there a big difference?
Not sure about the length youre referring to. I swapped to a aod from c6 when I swapped motors in my truck. Trans mount came foreward a bit, and i had to lengthen the driveshaft about 3 inches and change tail shafts.
Thanks for the information. Sounds like I may be able to get by with just altering the transmission mounting pad holes and not have to move/alter the crossmember.
The block to mount length is about the same as a C6; the overall transmission length is about the same as a C4.
I have PHOENIX Transmission Products Chart before me. The dimensions are: C-4 Overall length 30-3/4" Face-to-mount distance 20-3/4" C-6 Overall length 33-1/2" Face-to-mount distance 22-3/8" AOD Overall length 30-3/4" Face-to-mount distance 22-3/8"
