cable drive tachometer
Discussion in 'The Hokey Ass Message Board' started by chopt31, Mar 25, 2013.
  1. chopt31
    chopt31
    i have an old dual point with tach drive, question, is it just direct to tachometer? or does it need one of those sw reducers, also, where does one get a cable, short one
  2. Groovybaby6
    Groovybaby6
    from Denver
    Do you have a picture??
  3. CutawayAl
    CutawayAl
    from MI
    Whether or not you need a gearbox depends on the needed tach drive speed, and the ratio of the drive gears in the distributor. If the tach reads correctly as is then you are fine. If not, a gearbox, or tach servicing, is needed.
  4. Pete1
    Pete1
    from Wa.
    You can get a cable made up at almost any speedometer repair shop.
    Get the cable and hook it up to see how your head is calibrated.
    Then you will know if you need a doubler.
