Hot Rods Cable Gland Fittings
Discussion in 'The Hokey Ass Message Board' started by INVISIBLEKID, Mar 26, 2024.
  1. INVISIBLEKID
    INVISIBLEKID
    from Gilroy,CA
    Anyone using them? I see a need in certain area's, but then grommet's also. I'm using both........You?;)
  2. pprather
    pprather
    They appear to be made of plastic, which if there are no sharp edges, a grommet would not be necessary.
    I ***ume cable gland fittings are used for wiring homes and other buildings. They seem rather bulky for automotive use.
  3. miker98038
    miker98038
    Agreed. In my electrical background they were mainly used to terminate a cord (like S,SJ, SO) into a conduit box. I’ve seen them on boats used to terminate the flat wiring (marine rated fine stranded cable, looks like non metallic house cable like romex). I’ve got a little sample box around but the only time I used one on a car was a buddy’s street rod. It had a flat cable to a black box to control the column shift indicator. I needed to get it thru the firewall and used a flat version one with a little putty as a seal. Put it on the inside under the dash where you couldn’t see it. Otherwise on a cable bundle just a simple rubber grommet of the right size.
  4. Happydaze
    Happydaze
    I like grommets with the cable gland type funnel thing. Trim to length. Provides an amount of sealing and strain relief.
    Chris
