Cabover question
Discussion in 'The Hokey Ass Message Board' started by SHORTDOG, Nov 10, 2009.
  1. SHORTDOG
    SHORTDOG
    I want to know what's involved in converting a COE to a street cruiser like the one shown in the pic? :confused: What needs to be done and how hard is it to pull off?
    or better yet, Does anybody know who owns this truck and do you know how i can get a hold of the guy??
  2. fiddy9apache
    fiddy9apache
    from texas
    ive always wanted a COE with a slide out wrecker bed and modern drivetrain to haul my toys around on.
  3. Lobucrod
    Lobucrod
    Alliance Vendor
    from Texas
    Cut, weld, bang, grind, sand, paint
    kardude67 likes this.
  4. DonMan
    DonMan
    A lot of the COE`s I`ve seen are sitting on mid-80`s Chevy 1 ton ch***is.
  5. SHORTDOG
    SHORTDOG
    I was thinking of going mid 80's but i am not sure about going 1 ton or not. Would be good if i was gonna run a flat bed or duallies but i want to slam it and run a regular bed on it like the one in the pic...The only thing that will go in the bed is an Ice Chest! :D
  6. patrick66
    patrick66
    You might look for an old cube van/bread truck, such as a GM P-30, since the steering column is in nearly the perfect location for when you mount the cab to the ch***is. They are cheap as dirt, and available nearly anywhere you might look!
  7. ArtGeco
    ArtGeco
    from Miami
    Have you seen the COE thread?
    That'll keep you bust for a day or two.
  8. A COE is basically the same cab positioned a little differently, find a frame you like, make mounts and bolt it on. That said I'd suggest avoiding say, an S10 on this one.
  9. fat57
    fat57
    No problems just make a box tube frame to mount the cab over a S10 or C10 frame the small pickup in my photo section is on a C10 frame 350/350 and home made box great little truck
    Mark www.fat57custom.com
  10. wizard47
    wizard47
    1973- 1989 chevy truck frame works best for the 48-53 chevy coe. 1/2 ton 3/4 or 1 ton. doesnt matter. cut off the factory body mounts and set coe cab on frame. line up front fender openings on front wheel and start making new body mounts where needed. but those years are the best ch***is for a conversion. i have everything if your looking to start a project too. but that should get you started for sure.
  11. FlynBrian
    FlynBrian
    If you use a 80's gm 1 ton dually ch***is, steering box out of a 80's 1/2 or 3/4 ton gmc or chevy van will get your steering column geometry right.
  12. tommy
    tommy
    A buddy of mine has a 56 Ford cabover mounted on a 3/4 ton Dodge van ch***is. The short nose van ch***is might require less steering and suspension relocating than a conventional P/U ch***is. Get out your tape measure.
  13. metalman
    metalman
    Do you allready have a COE to start with? A local builder has one like the one in your pic for sale, already set up on a late GM ch***is, I believe it runs and drives. Ready for paint, upholstery, ect. I think it could be bought right and the guy is a good builder so it sould be done right. PM me if your interested, I'll send you the info.
  14. GaryN
    GaryN
    I built a '46 Chev COE a few years ago. '75 Chev 1 ton ch***is, stretched 6', 40" Freightliner bunk, 18' drive on deck, 175 HP Isuzu turbo diesel, 5 speed main and 2 spd. aux.
    I found that unless your going to use it for a business a truck this size is just not practical. Too much gov't. red tape to keep it legal, at least here in Ontario. If I did it again it would be a pickup style so it could be licenced for personal use only and not commercial.
  15. Locomotive Breath
    Locomotive Breath
    from Texas
    That is a sharp car hauler :D
  16. oldy57
    oldy57
    I have a few questions about the 48-54 COE Chevy cabs. Are they the same doors as a 1/2 ton cab. Also is the cab the same width and height. The COE looks taller but that could be because of the step section under the doors.
    Could you cut the back of a panel truck and mount it to the back of a COE. You could have a COE panel, short box or long box panel. I have not seen a COE in person so I have no idea of size. Can anyone do a Photoshop of this.
  17. GaryN
    GaryN
    I've seen a panel body grafted to a COE cowl. The COE doors are unique to the COE due to the cut out in the lower front corner for fender clearance. Yes the cabs of the 48-54 AD trucks are the same physical size but again the COE doors and rockers are different due to the fender location. Not sure of the model numbers but some of the bigger ones do have wider fenders.
  18. GaryN
    GaryN
  19. rusted_nut
    rusted_nut
    from Arkansas
    You forgot SPEND
  20. Atomsplitter
    Atomsplitter
    I'm not sure how to get hold of this guy but you may try the shop name and phone number on the door. Otherwise try Bill at Bill's Truck Shop in Courtice, Ontario, Canada as it's posted as a customers ride in his web site gallery.
    http://www.billstruckshop.com/customers_gallery_47-55.htm
  21. dave lewis
    dave lewis
    from Nampa ID
    Short, find a cl*** A motorhome..controls already up front...I have an 84 30' on gm ch***is...454/t400, dual rear wheels..just a tick under 50k miles.
    perfect for a cabover!
    Dave
  22. dave lewis
    dave lewis
    from Nampa ID
    Dave
  23. J Man
    J Man
    from Angola, IN
    Motor home and van ch***is seem to be the bast as far as placement of the front suspension.
    Check out the newest issue of cl***ic trucks (yellow C10 on cover), there is a blue one in there.
