Cad 331 oil pressure problem..help!
Discussion in 'The Hokey Ass Message Board' started by kidagin, Jul 15, 2008.
  1. kidagin
    kidagin
    from Florida
    First time I've rebuilt a Cadillac 331. I got very low oil pressure. I know the bearings are correct and the pump is rebuilt. Are there any hidden galley plugs or bypass problems I might have missed? Anything peculiar to the 331 that comes to mind? I'm probably overlooking something simple and will no doubt feel like a stump when I figure it out, but any input is welcome. Thanks
  2. Kirk Hanning
    Kirk Hanning
    Is your oil filter canister set up properly? Inlet/outlet, pinched oil line? When rebuilding the motor did you have the oil pump apart and repack it with a bit of axle grease?
  3. Sloppyseconds
    Sloppyseconds
    from Pasadena
    How low... what are the specs on the oil pump compaired to what you are getting?
  4. jesus valencia
    jesus valencia
    from pomona
    there is a plug on the inside of the block in front of the distributor gear. If you look at the back of the block there is on on the right side but that one is outside. It was when they drilled out the oil holes on each side of the banks for the lifters but you cant get that side from the outside because the distributor. If that plug isnt in there you wont have oil pressure. If i remember correctly you it is behind the left side plug if your looking at the back of the block. Hope this makes sense. I built a 52 motor last year but my memory isn't all that great.
  5. Aaron65
    Aaron65
    from Michigan
    I don't know how Cad oil pumps are set up, but having a ~.003 inch gasket under the cover plate for the gears dropped my oil pressure in my Buick by about 10 lbs. at cruise...no gasket--back to specs. Might be something to check out...
  6. kidagin
    kidagin
    from Florida
    Thanks for the input. The pump was rebuilt by a shop in Texas, I did not take it apart to mic it or pack and prime it. I will look for the galley plug and insure it is there. I'm thinking it is bypassing one of the galleys. Pressure is 4-5 psi.
  7. Dirty2
    Dirty2
    I hope it wasnt a shop in ft. worth .
  8. Aaron65
    Aaron65
    from Michigan
    Take apart the pump and have a look under that cover. If there's a gasket, get rid of it and check clearances between the gears and the pump. If there's enough clearance, that might be your problem. Also, you'll be able to check your bypass...Do you know the clearances you built into the motor? Did you do the cam bearings?
  9. kidagin
    kidagin
    from Florida
    Problem solved! Jesus was right about the the galley plug in front of the drive gear for the distributor. A rookie mistake on my part. Thanks to everyone for input.
  10. Aaron65
    Aaron65
    from Michigan
    Great! Everyone makes mistakes--at least this one was an easy fix!
