CAD drawings - ford chassis...
Discussion in 'The Hokey Ass Message Board' started by autocol, Feb 4, 2004.
  1. Mule Farmer
    Mule Farmer
    from Holland MI
    Tools would be cool to tubing benders , english wheels , heave hamers ,all would be cool.
  2. banzaitoyota
    banzaitoyota
    My current project is a 31' Long Replica of the USS SKIPJACK SSN585; we are building a parade float for our USSVI Chapter. Sub is being laid out in Microstation then I will export to BOBCAD. After tweeks the skeleton will be cut on my buddies SHOPBOT
  3. scootermcrad
    scootermcrad
    Screwing around with some stuff here... Not entirely accurate by any means, but it has helped me with a couple things in terms of the wheels base and interferences.
  4. 100mph WHEELSPINNER
    100mph WHEELSPINNER
    I Use Solidworks Everyday.......i Love It. I Want A Detailed Model Of A Small Block Chevy.....
  5. Big Earl
    Big Earl
  6. scootermcrad
    scootermcrad
    There is one on here complete with water pump, manifold, etc... Forget who did it. Do a search for CAD. I think it might come up. The guy who started it is on here quite a bit...
  7. OLLIN
    OLLIN
    this is great. I dont think people fully realize all the possibilities hear. 3D models can also yield 2d dwg files, the dwg files can be used to make brackets, plates, spring perches etc on the waterjet/CNC machine.
    The 3d models can also be on the cnc and you can make molds for stuff like for fibergl***/vacuum forming etc.
    A downloadable library for members would be awesome! Instead of trying to email everything to everyone that asks.
    I will submit anything i come across too!
  8. I couldn't agree more.
  9. Vance
    Vance
    from N/A
  10. first24q
    first24q
    from Ma.
    I have talked with Wescott and asked them if i could take 34 drawing off the site and they said ok.I have a .dxf or .dwg drawing of a 34 ford frame.I scaled down the one from Wescott.I am building a 1/4 scale rc 34ford.If you need it ley me know.I will help you if you want.
    ED
    Theunsb likes this.
  11. v8minor
    v8minor
    I am interested in learning cad .. How hard is it ,could a dropout like me learn it ??.
  12. Do you have any drafting experience?
  13. 4tl8ford
    4tl8ford
    from Erie, Pa
    Does anyone have a dimensional drawing of the 46 - 48 Ford Ch***is in MS Word or PDF?
    rctree(dot)netzero.com
    Thanks
  14. The Big M
    The Big M
    I use SolidWorks too. No hot rod parts specifically, but I do plan to design a disc brake conversion for my pickup once I can get some accurate measurements.
    (Nice avatar, btw. ;) )
  15. atch
    atch
    like rdaugird asked: are you proficient in drafting or engineering? or at least in reading blueprints? i've been doing autocad for about 15 years now; before that i did design work with pencil/paper. my experience is that if you can't do any drafting on paper then you probably won't be able to draft in cad. but if you can draft on paper and you're reasonably computer literate then you'll prolly do just fine learning cad.
  16. AllSteel34
    AllSteel34
    I have a copy of his model in .igs format. PM me and I'll send it to you. I haven't verified it dimensionally, but it appears to be a good model.
    Chris
  17. I'd say atch is probably right, I started AutoCAD in '89, but had been drafting since I was in jr. high. I wouldn't say you COULDN'T learn AutoCAD, but basic drafting is a plus. Either way, give it a shot, especially if you have access to the program. You can buy a book with a student version(it works the same, but prints"Student Version" on the edges of the page) for around $100 U.S., a bargain, AutoCAD costs thousands of dollars!
  18. v8minor
    v8minor
    Thanks no real background , I am a bodyman by trade also worked in the aircraft field for a while , I do some drawing and can read blueprints . I have started in a RV dealer and we are starting to manufacture .I Have the job of making the fibergl*** caps ,it would be nice to design then on CAD for the customer . I think I will try and get my head around it .
  19. By all means, try it. I draw almost everything I build in the garage on CAD, I love it! I have designed tons of stuff I'll probably never build, and saved a lot of $$$ on materials figuring out things that won't work or will work better. Also great for making patterns, depending on your printer size. We have a printer at work with a 48" roll of paper on it! I don't know if they have Kinko's or any equivilent in Ireland, but they will print CAD files full size, I did that in the past.
  20. Theunsb
    Theunsb
    Good morning. I just came across this post of you. I'm situated in Australia and want trying toget hold of a 1/4 scale Ford ch***is and body. Is it possable to send me the scaled files for the ch***is. I will apriciate it if you can. Do you hava any info or drawings on the body and front / back suspention. My email is theuns.beck@gmail.com Thank You
  21. Theunsb
    Theunsb
  22. Paul
    Paul
    Editor
    This thread is nearly 11 years old.
  23. topher5150
    topher5150
    I'm not sure what software you are running, but in Solidworks you can import a picture (I forget what format it is) scale it and basically trace the lines.
