Technical CADDY INLET MANIFOLD
Discussion in 'The Hokey Ass Message Board' started by Burnout64, May 18, 2021.
  1. Burnout64
    Burnout64
    Hi all, does anyone know if an aftermarket inlet manifold, such as offenhauser from a 390 Caddy will fit a 64 Caddy 429 motor? or if it can be modified? thanks, just having trouble finding anything listed for a 429....
  2. squirrel
    Hollanders says the stock intake is the same from 63-65. That covers both engine sizes. And the 390 and 429 use the same intake gaskets. The distributor moved up front on the 429, but it doesn't seem to have changed the intake manifold...unless there's something I'm missing...if it's a multi carb intake, it might be in the way?
    offy catalog says their intake fits up to 63.
  3. Roothawg
    Roothawg
    What year 390?
  4. Burnout64
    Burnout64
    Looking at the Offy manifold which fits 49-62 , although if people have used others I would be interested to know
  5. squirrel
    does it have a number? or do you have a picture of it?
  6. Roothawg
    Roothawg
    In 63 the distributor was moved to the front of the engine, so the intake are more than likely different. The exhaust manifolds are about the only thing that stayed the same, I believe.
    squirrel likes this.
  7. Burnout64
    Burnout64
  8. Off the top of my head, I think I remember that there were two different 390s.
    You'd need the later one.
  9. 62ish up to 67 is a different engine
  10. southerncad
    southerncad
    loudbang, mgtstumpy and alanp561 like this.
  11. kadillackid
    kadillackid
    Intakes are wider , you can physically fit a 49 to 62 6 X 2 intake by using longer plenum hoses , so very limited choices unfortunately :(
    Barrelnose pickup likes this.
  12. Burnout64
    Burnout64
    Thanks for info guys
    kadillackid likes this.
