Technical Caddy lifter preload?
Discussion in 'The Hokey Ass Message Board' started by anthony myrick, May 2, 2021.
  1. How do you guys check lifter preload on a caddy 472/500?
    My fresh build is making a rocker arm noise.
    I’ve never had to check a preload. Just adjust. These guys are different.
  2. 38Chevy454
    38Chevy454
    Do the Cadillac engines even have single adjustable rockets? Going from memory, I thought they had nonadjustable valvetrain. At least factory GM, unless you have the aftermarket roller rockers?
    Sent from my SM-A102U using The H.A.M.B. mobile app
  3. Non adjustable.
    Pedestal mount. Seems like a mystery, haven’t found much info. Even the cad co stuff is vague.
    I was told to remove .020 from the pedestals.
    The caddy needs .020 preload.
    I used a lunatti cam and lifters. This thing sounds like a solid lift engine.
  4. mgtstumpy
    mgtstumpy
  5. Lloyd's paint & glass
  6. Several.
  7. Lloyd's paint & glass
    Couldn't be just that the lifters aren't fully pumped could it?
  8. That’s possible.
    The caddy set up is weird.
    If my cam has a lower base circle, the rockets will be loose.
  9. Lloyd's paint & glass
    Yeah I've never messed with one. If you need preload, would it be easier to go with a longer pushrod? Or would it screw up the geometry?
  10. That or machine the rocker arm stands.
    But how much is the question
  11. sunbeam
    sunbeam
  12. Lloyd's paint & glass
    I'd give it more run time, recheck the torque on the rocker stands, and see if it helps before i went too crazy lol.
  13. Thanks
  14. sunbeam
    sunbeam
    check edited post
  15. Yep. Thanks again
  16. Fordors
    Fordors
    You mentioned the possibility of a smaller base circle in post #9 and that has to be your problem. For some reason the base circle on Lunati’s Cadillac cams must be smaller and that eliminates the lifter preload. As Lunati tech’s suggested the easy (and cheapest) way to correct your problem is to mill .020 off the rocker stands. It sounds like they have experience with this issue on Cadillac valve trains using their cams and you could use longer push rods but it will be more economical to mill the rocker stands.
    If .020 doesn’t sound like enough you could go .030, that would be the same as 3/4 of a turn on a Chevy rocker nut.
    anthony myrick likes this.
  17. I was suggested that. I have extra stands
    Is that Lunatti info?
  18. oldolds
    oldolds
    I suspect the problem is because there are no high lift cam blanks made for that engine. They are taking a stock lift cam and regrinding it. So essentially they are giving the cam more low instead of more lift. That is why you need to machine the towers.
  19. Well, I bought some lifters from the Cad Company. They are confirmed US made.
    The Cad Co lifters are .011 taller than the Lunatti lifter. The push rod cup is .009-,010 higher as well.
    F00D2C2C-0CD9-428F-9075-6E9DA630D4A6.jpeg 69463777-0581-4976-8259-5DD93A4BFD25.jpeg
    the Cad Co lifter is on the left
    winduptoy likes this.
  20. New lifters in. Scared me at first. Took a little bit to pump em up.
    A lot quieter now
  21. kadillackid
    kadillackid
    Great outcome !
  22. Well, we ain’t done yet.
    Idles great. Runs a little rough around 1500rpm.
    Set timing with a vacuum gauge.
    Gonna investigate carb base gaskets. I used a 68 intake. No EGR. That has a stainless plate under the carb. That’s there but I’m not sure if we have it all figured out yet
    Is seems it’s a gasket followed by a stainless ‘shim’ then the carb.
    that seems odd.
  23. doyoulikesleds
    doyoulikesleds
    all of them i have seen have a gasket on bolth sides of the shim
  24. I was wondering that. A gm manual I found online says only one gasket between the intake and shim plate.
    Greg Rogers likes this.
  25. 37 caddy
    37 caddy
    from PEI Canada
    You should go to the Cadillac-Lasalle club forum and ask this question there, there is a special way to install that spacer? A lot of smart guys there that could help you out.Harvey
  26. Greg Rogers
    Greg Rogers
    Glad you got the lifter situation resolved, Tony. I had the same situation on a small block Olds. Wanted to use original pushrods/lifters after a cam change to a "original type grind" cam. I probably had .040 clearance on all rockers when fully tightened. I had some adjustable Mondello pushrods and had to use them and set all individually. It was a PIA! I wonder if those longer lifters you got are available for other engines that don't have a adjustable valve train?
  27. Onemansjunk
    Onemansjunk
    from Modesto,CA
    If your intake manifold has the exhaust cross over to heat the carb - would a exhaust type gasket be required between the intake and stainless block off plate?
  28. I think the longer ones are maybe the correct ones and the other ones were too short. I still have an original I could compare them with
  29. I’m going to order a 68 intake gasket. I’m using a 68 non egr intake.
    I’ve had a similar issue with ford once
