Caddy motor questions
Discussion in 'The Hokey Ass Message Board' started by enjenjo, Dec 11, 2004.
  1. enjenjo
    enjenjo
    from swanton oh
    I'm getting ready to build a 390 Caddy. Any place I can get tech info beyond bore and stroke? Nothing i have found yet goes into any depth, and I am planning some modifications that require more info.
  2. Rocky
    Rocky
    Classified Editor
    I can help with the standard compression ratio, crank journal sizes, torque specs cam timing, rod and main clearances, piston pin sizes and some carb settings...the stuff Chiltons' always has.
  3. enjenjo
    enjenjo
    from swanton oh
    I have the normal specs Rocky, I need things like port volume, bearing width, compression height, head cc, cam specs, you know, more, more MORE!!!
