Cadillac 331 oiling question
Discussion in 'The Hokey Ass Message Board' started by EnVoloNosFides, Feb 6, 2011.
  1. EnVoloNosFides
    EnVoloNosFides
    from Salem, OR
    Hey all,
    So I have a 1949 Cadillac 331 V8 and am trying to figure out which of the two oil ports by the distributor is the oil "out" port and which is the oil "in" port - they've both been blocked off since I've owned the motor and the manual hasn't been any help. There's one that's on a flat surface and one that's angled (if you've seen this type of engine before, you'll know what I mean).
    Anybody got any advice on this matter?
    Thanks!!!
  2. r8odecay
    r8odecay
    I think they are both an 'out'....this pic is from my 51 book; I read it that the angled port is for the pressure sender, and the straight port is plugged, coming from the rear main.
  3. EnVoloNosFides
    EnVoloNosFides
    from Salem, OR
    Okay...
    So where do I plug in the oil lines then? I'm stumped.
  4. Just plug them both and throw away that ineffective filter system.
    I have rebuilt a '53 Cad 331 for my 'someday' roadster project and
    plan to leave all that stuff off. They look so much better without it.
    Just change the oil a little more frequently and keep an eye on its
    condition on the end of the dipstick. Really! If it bothers you about
    the thought of regularly changing out oil that still might have some 'life'
    in it, then tip it in some more modern hack that has a modern full flow
    filter and get a second use out of it. I removed the filter and lines on
    my '50 ford flathead and change the oil every 2500 miles. Then I put it in
    my father's 80's T*y*ta and he burns it up in that old thing. How 'green'
    is that??;)
    CM
  5. r8odecay
    r8odecay
    If you are talking about where to mount the canister filter, the ports for the filtration is up front, not back.
    one on the top of block, one on the front face...
  6. EnVoloNosFides
    EnVoloNosFides
    from Salem, OR
    r8odecay - do you know which port is in and which is out?
    Thanks!!!
  7. austin514
    austin514
    the top is the out line and the bottom is the in . i just put the filter back on my car 2 weeks ago .
  8. r8odecay
    r8odecay
    verbatim from the manuel:
    A drilled and tapped hole at the top of the left cylinder block near the oil filter housing intersects the header which lubricates the left rocker arm. Another drilled and tapped hole at the front of the left cylinder block, near the water pump to block inlet, intersects the oil drain back hole from the cylinder head. These holes are provided for the installation of the Oil Filter inlet and outlet connections. The inlet pipe should be connected at the top of the block, and the outlet pipe from the Filter to the front of the block.
  9. terd ferguson
    terd ferguson
    Here's a really dumb question. Which is the in/out on the stock filter canister??
