Hot Rods cadillac 365 head interchange
Discussion in 'The Hokey Ass Message Board' started by vetteson, Sep 18, 2017.
  1. vetteson
    vetteson
    I am interested in installing 365 heads on my '55 Cadillac 331. Are there any major differences in the three years. I've seen that early '56 heads cracked a lot. There is an early part number and a later part number, depending upon VIN. They ('56-8) all have different part numbers. I know the valve sizes are the same. I don't know of combustion chamber differences, drain hole differences, various mounting bosses. I know I need a right and a left and I guess I would use 331 head gasket.
  2. morocco mole
    morocco mole
    from London, UK
    Hi vetteson, I too would like some advice along these lines as I’m intending to try to do the same also. I’m also wondering if I can use the early 390 intake on top of that setup because it’s supposed to be the best intake for these engines. Anyone got any experience of this, plus how about swapping the carb to a Holley?
  3. warbird1
    warbird1
    All of the intakes will interchange between 331, 365 and 390. A Holley will fit the 390 intake with an adapter, but an AFB or Edelbrock will bolt right on. As far as the head swap goes, just be sure you have to correct rocker arm ***y. and head bolts for the heads you use...
    ls1yj likes this.
  4. ls1yj
    ls1yj
    from Kentucky
    May need the pushrods from the 365 also, to keep geometry correct
    warbird1 likes this.
