Cadillac 390.....Any Good?????????????
Discussion in 'The Hokey Ass Message Board' started by striper, Jun 19, 2008.
  1. striper
    striper
    I have an opportunity to pick up a complete 390 (1960?) with a ****** for a couple hundred dollars. Owner says it needs rebuilding. It came out of his '55 when he put a SBC in it.
    I know little about Caddies but of course being a '55 I had hoped for a 331.
    What can you tell me about this motor? Are they compatible with the earlier ones or totally different? Speed parts? What ****** would it have?
    Any education you can provide will be appreciated.
    Pete
  2. 1960 could have the dual-coupling hydramatic or would bolt to a slant-pan hydro. Both good transmissions. There was a thread on here the other day, a guy put one in a tractor and ran it as a farm machine for years. Cadillac sold several hundred thousand of them.
    On the other hand I just junked one, I couldn't find anyone who gave a damn about it, so I picked some pieces and s****ped the rest. '60 is the first year for a full flow oil filter.
  3. striper
    striper
    Thanks for the start of my 390 education. Anyone else?
  4. GREASEMONKEY72
    GREASEMONKEY72
    i say grab it and use it
  5. naki kid
    naki kid
    The caddy 390 came out in 59 not in 55 must have been put in by someone.It is a real good motor I think around 335 horse the eldo had triple carbs and 345-350horse.
  6. striper
    striper
    Sounds good. I think I'll grab it.
    I just didn't want to get it only to find it was the ugly duckling of the Caddy motors.
    I don't own a boat so an anchor would be no good to me.
    Would the trans be a 4 sp Hydro?
    Pete
  7. Dirty2
    Dirty2
    I have a 51 331 in my car and bought a 59 390 . Very nice looking motors but very costly to rebuild .
  8. striper
    striper
    They're all costly to rebuild out here. Except SBCs. I don't think I should let that stop me.
    Anyone have pics of a nicely dressed one? Or a nice stocker?
    Pete
  9. DeVille Gal
    DeVille Gal
    We put a 390 in our '57 Coupe de Ville with a tri-power set up (I think I am saying that right), runs well now. I'll email my husband Slick50 and ask if he saw this thread for his input.
  10. striper
    striper
    Thanks, the more feedback the better.
  11. Dirty2
    Dirty2
    Pull up posts by evil . His is nice . I wasnt knocking the price just warning you . I know MONEY is no object for some people tho.
  12. notebooms
    notebooms
    Alliance Member
    i dont think these motors are more expensive to rebuild than other interesting motors-- like a Nailhead, etc. sure, small block chevy's are lower cost-- but they are cheaper because they are a commodity-- everyone has them. if you're looking for something with a lot more soul than a SBC, this is a great motor.
    Parts such as valve covers, intakes, etc will inner-change with the 331/365. The 390 is basically the same motor-- with improvements through the years and additional bore and stroke.
    i've built and run about 4 different 390's through the years in different cars, and have another one planned someday. i dig 'em.
    -scott noteboom
    j-jock likes this.
  13. Dreddybear
    Dreddybear
    I've got a 61 390 for my girlfriends A pickup. The earlier script valve covers fit right on. They're pretty, great sounding motors. Search for Jonny Cola's model A. I know he's got a 390 with 6 dueces. Awesome lookin motor.
  14. striper
    striper
    Thanks guys. That's the sort of stuff I was after... compatability with ealy stuff and so on. Do I keep the hydro?
    Dirty 2. It's not that money is no object but let's face it, if it was all about money none of us would be doing what we are doing. It all costs. As you know it just costs a bit more for something really cool. And thanks, I didn't know evel's was a 390.
    Cheers, Pete
  15. Im running a 365 in my shoebox. There are a few companies that make adapter kits to run a manual or a newer gm auto ******. Kanter has alot of rebuild parts/carb kits/what-not for em. I would plan on putting a new water pump on that motor.
  16. Silent_Orchestra
    Silent_Orchestra
    from Omaha, NE
    Correct me if I'm wrong but isn't it similar to a 303, 324, and 371?
    I think the old Caddy and Olds engines are pretty sweet myself. I'm a ****er for most old engines though, mainly Olds, but Poncho, Buick, Caddy, and a little bit of Stude, or AMC here or there makes me happy too. All inline engines get me all warm and fuzzy on the inside though. Ok now back to the thread!
  17. HasonJinkle
    HasonJinkle
    Pete-
    If at all possible, try and pick up the May 2008 issue of Hot Rod Deluxe as there is a very good build article on a basic overhaul of a '59 Cad 390- after reading that, I'd definitely keep one if it was given to me. I won't rewrite the article here but they dynoed it after the rebuild and, while the peak HP was only 286 @ 4800, peak torque was 383 @ 3000 and was over 320 lb-ft from 2800 to 4600 rpm. And that's with a piece of **** Carter WCFB 400 cfm carby. This was with a .027 overbore and a pretty basic overhaul- new pistons and bearings, a Steve Long Racing cam and new timing chain. They port- matched the heads and did a little cleanup in the runners. That dead flat torque line is pretty ****ing awesome, I'd like to see what this rebuild would do with about a 600-625 carb on it that can actually flow!
    You can get all overhaul supplies for it from Egge's. I'd go ahead and run it if I were you, it's a hell for stout low revving torquer, it won't cost you a mint for a basic overhaul, and it's different.
  18. striper
    striper
    Well I just picked it up. It has the carb, generator, power steer pump and trans.
    I'm very curious to get it pulled down because they guy who I got it from was told it had been recoed when he bought the car. When he couldn't get it to turn over he pulled it and installed a SBC.
    It very obviously has new gaskets, freeze plugs and a full sump of clean oil etc. I'm quietly hoping that it has had a rebuild and there's something simple stopping it from turning. It did turn about 1/2 a turn then stopped he said.
    For $300 I figured it was worth a gamble.
    Thanks for the info so far and I'm happy to hear more
    Pete
    j-jock likes this.
  19. Dirty2
    Dirty2
    Heres you an intake on ebay . This is the one I have on mine .
    <TABLE cellSpacing=0 cellPadding=0 width="100&#37;" bgColor=#ffffff border=0><TBODY><TR><TD><TABLE cellSpacing=0 cellPadding=0 width="100%" border=0><TBODY><TR><TD>Cadillac Edelbrock 4X2 Intake CD-694 331 365 390</TD><TD cl***=***lecell2 noWrap width="10%">Item number: 320265396533</TD></TR></TBODY></TABLE>
  20. Marty McFly
    Marty McFly
    If you were going to try to find a dual 4 barrel intake for it I have a AFB from a '65 Cady 390, carb # 3904, you could use for a front carb. The choke was removed and it is very clean, needs a kit though. It was on a BBC dual quad intake I bought a few months ago. PM me if interested, I will make you a great deal!
    Sorry, shameless self promotion.
    Mart McFly
  21. jonnycola
    jonnycola
    I love caddy motors. Here's one in my model A. It's a '62 390.
    Evel's got one of the best dressed ones I've ever seen
    Mr sloppyseconds does too...
    Pictures stolen from Coop.
  22. 40StudeDude
    40StudeDude
    If I'm not mistaken...R & C just did a "build" on a 390" Caddy motor...or maybe it was Rod & Kulture...or one of them anyway...it was pretty extensive and covered all the idiosyncrasies of the engine...perhaps someone else will remember where the article was...
    R-
  23. GaryM
    GaryM
  24. striper
    striper
    Now we're really cooking. I don't have any plans for the motor just yet. I have a 36 5W that was going to get a 48 flat head. Maybe a Caddy would be cooler? I love multiple carbs but the nailhead that is going in my A has 3x2s so I'm thinking maybe 2x4s. Anyhow I suppose I should just start collecting and see where it leads me.
    On the trans adapters...does it need a 4sp or is the Hydro a good choice?
    Thanks for all the help guys.
    Pete
  25. striper
    striper
    Thanks,
    Someone else posted earlier that it was May Rod and Kulture. I'll have a look at the newsagent today.
    Pete
  26. hotrod69
    hotrod69
    from warren tx
    i did the rebuild work on my 390 and found the engine to be very close to a sbc, but much improved. the intake is easy to change because it comes off with out getting into the water jacket or the distributor, the only problem is the non adj. rockers,intakes are hard to comeby as well as water pumps, the rest is readly avalable
  27. KustomKid9
    KustomKid9
    Hey guys can u help me I just bought a 1959 caddy 390 engine and i have a 1950 caddy 62 cp will this engine fit with no problem in my 50 caddo
  28. warbird1
    warbird1
    Dogberg likes this.
  29. Dogberg
    Dogberg
  30. john W.
    john W.
    My 60 caddy ELDO has the 390 3x2 Rochesters.
    Stock rebuild on Dyno said 275 bhp.
    Thinking progressive linkage.
