I am looking at buying a 62 Caddi. The only thing is, oil is blowing out of the vent onto the engine (not a ton, but some). What would cause this? Is this a major issued or minor?? Please let me know. Thanks!!! See picture for details.
If it's blowing out the breather tube,or oil fill tube, it could be "blow-by" from worn piston rings allowing combustion gases to to pass into the crankcase and out the breather. This may not be the problem, just a possibility. Do you get any blue/white smoke out the exhaust(indicating maybe worn rings or valve guides)?
With only the info given, some people would say that the engine may need a rebuild. If it is pretty high mileage that might be the case. However, a engine that has worn rings may serve you for 20,000 more miles. A compression test at a local garage will reveal a lot about the engines condition. You can also do that yourself. It's not beyond the amateur mechanic to do it.
